(Topic ID: 228068)
Bally -35 boot issues: LED locked on
By Brewchap
5 years ago
  • 42 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by zacaj
#1 5 years ago
I have a pulled MPU -35 that I am wanting to repair. I have tried to work on this myself using pinwiki once before. I have replaced all sockets and have a set of new burned ROMs. The board has also be jumpered to use these new ROMS. Also to note that this board had no battery corrosion what so ever on it. But the LED still stay locked on. I have also tested the CPU and PIA chips to make sure that they are good with another board.
What I would like to do is start from scratch, but I'm not sure where to start.
20181026_160745 (resized).jpg20181026_160745 (resized).jpg20181026_160759 (resized).jpg20181026_160759 (resized).jpg20181026_160815 (resized).jpg20181026_160815 (resized).jpg
#2 5 years ago
Quoted from Brewchap:
Take everything out except the roms, cpu, and led pia, then use a logic probe to check if all the inputs to the pia are functioning.
Could also be a bad clock for the cpu
#3 5 years ago
Do you ROMs match the jumpers on the board?
#4 5 years ago
Quoted from zacaj:
I'm not sure looking at this print which is the input. Also am I looking for high or low signal or pulsing?
#5 5 years ago
LED is on U11. Check everything on the left side. I would expect everything except the bottom 3 to have activity. (and maybe 37+38)
#6 5 years ago
Quoted from eh97ac:
Yes, I had the same problem with the original chip before the legs broke off
#7 5 years ago
Quoted from zacaj:
U11 Gotcha. I have no activity at all on any pin.
#8 5 years ago
Alright, back to the CPU checking activity. You should see movement on 3 and 37 from the clock (coming in from U15), or else the CPU won't run. If it's running you should see activity on the Address and Data lines
#9 5 years ago
Quoted from zacaj:
There is nothing on 3 and 37 on the CPU.
#10 5 years ago
The jumpers look suspect and there is a wire jumper on the back of the board. I'm guessing some bad traces and soldering mistakes too.
#12 5 years ago
Do you have any other working MPUs you could compare with? The clock signals are fragile enough that sometimes just reading them with a logic probe will mess them up, but usually it's fine. If the clock circuit isn't sending the proper signals into pins 3+37 of U9 then the CPU will never start. Probably U15 or U16 is bad, but they're both hard to come by
#13 5 years ago
Looks like GPE has U15 and U16 in stock.
Here is my reading if this helps.
U15
pin 7 low
pin 8 high
pin 9 pulsing
pin 10 pulsing
pin 11 high
pin 12 pulsing
pin 13 pulsing
pin 14 high
U16
pin 1 nothing
pin 2 nothing
pin 3 high
pin 7 pulsing
pin 8 low
pin 9 pulsing
pin 10 pulsing
pin 11 high
pin 12 pulsing
pin 13 high
pin 14 nothing
pin 15 nothing
I can get another board on Monday, but it has corrosion damage on it and does not boot up. How far it boots I don't know yet if it does.
#14 5 years ago
U15-8 should be the inverse of 9 and 10, so I think it's definitely part of your problem, unless something has shorted pin 8. Can also try reading pin 8 with the CPU removed to see if that changes anything.
#15 5 years ago
No change on pin 8 with CPU removed.
#16 5 years ago
This board don't boot. I pulled the CPU and PIA's. LED dont even light up. Think that I'll pull U15 and try that on my other board.
No. Wash the junk off too see just how bad it really is.....
20181029_195258 (resized).jpg20181029_195258 (resized).jpg20181029_195313 (resized).jpg20181029_195313 (resized).jpg
#17 5 years ago
ok I changed U15 and now have pulsing on U15 pin 8 and on the CPU pin 3 and 37. Still have a solid LED light with all chips in.
#18 5 years ago
OK cool. Now go back to checking the pia inputs
#19 5 years ago
Have you tried jumping pins 39-40 of u9 to see if you're not getting 5v stable quick enough? This is my bible:
http://techniek.flipperwinkel.nl/ballyss/rep/index2.htm#flash
#20 5 years ago
U11
36 pulsing
35 pulsing
22 pulsing
24 pulsing
23 pulsing
33 pulsing
32 pulsing
31 pulsing
30 pulsing
29 pulsing
28 pulsing
27 pulsing
26 pulsing
38 high
37 high
25 pulsing
21 pulsing
34 high
20 high
1 low
#21 5 years ago
U10
36 high
35 pulsing
22 pulsing
24 pulsing
23 pulsing
33 High
32 pulsing
31 low
30 pulsing
29 pulsing
28 pulsing
27 pulsing
26 pulsing
38 high
37 high
25 pulsing
21 pulsing
34 high
20 low
1 low
#22 5 years ago
So, CPU is now running and sending commands to the other chips, but the PIA isn't getting the specific command it needs to turn off the LED... Is this with just the ROMs, U11, and U9, or do you still have other chips installed? If not, I'd suspect the rom jumpering first of all (what rom types are you using?), otherwise something must be messing with the address/data lines..
#23 5 years ago
Just the ROMs, U11, and U9. Ill inspect the ROM jumpering again. The chip is a M2732A-2f1
#24 5 years ago
E4-13a, 7-8, 10-11, 12-GND, 16a-29, 31-32, 33-35 ( E13-15 Jumper CUTS)
#25 5 years ago
I dont think that I did the jumper cuts...
#26 5 years ago
It looks like E13-15 aren't jumpered to begin with in your original picture? What's that one wire on the back?
#27 5 years ago
The wire on the back is a jumper on a trace that I messed up on when I was replacing the socket. I pulled the socket out along with the trace. OUCH!
#28 5 years ago
Quoted from zacaj:
correct
#29 5 years ago
Jumpers are correct.
#30 5 years ago
I guess you should check the pins on the other chips then. Roms should have activity on 1-11, 13-19, 22,22. Low on 12, high on 24.
CPU should on all the A and D lines, as well as 34 and 5
#31 5 years ago
Quoted from zacaj:
You got 22 listed twice...
#32 5 years ago
Quoted from zacaj:
U6 tested correct while, U2 all tested correct but 18, which was low.
#33 5 years ago
CPU
A0/9 High and low on
A1/10 Pulsing
A2/11 Pulsing
A3/12 Pulsing
A4/13 High and low on
A5/14 Pulsing
A6/15 Pulsing
A7/16 Pulsing
A8/17 Pulsing
A9/18 Pulsing
A10/19 Pulsing
A11/20 Pulsing
A12/22 Pulsing
A13/23 Pulsing
A14/24 Pulsing
D0/33 Pulsing
D1/32 Low
D2/31 Pulsing
D3/30 Pulsing
D4/29 Pulsing
D5/28 Pulsing
D6/27 Pulsing
D7/26 Pulsing
#34 5 years ago
This is with chips U2 U6 U9 and U11 installed
#35 5 years ago
Oops. Should be 22, 23.
With your specific jumpering (E12 - GND) that's correct.
what do you mean by "high and low on"?
This seems weird. This pin on U9 should be connected directly to the D1 line on the roms (pin 10) and PIA (pin 32), both of which you said had activity. Do you have good continuity between all of them? Maybe a bad socket or trace somewhere...
#36 5 years ago
Quoted from zacaj:
Yes I have good continuity between all of them
Quoted from zacaj:
That both lights are on when testing that pin
#37 5 years ago
Quoted from zacaj:
This has me confused. I have gone back to double check the readings and they are not pulsing anymore. The continuity is good as I have checked that over and over again.
I'll keep looking.
#38 5 years ago
I'll keep looking.
It should be pulsing at all 4 places. If it's not you might have a short somewhere or something. I even have one board with a problem like this where somewhere along the pcb the trace is actually cracked, so if you flex it it'll read different :/
#39 5 years ago
Which pin from U15 will the pulsing come from?
#40 5 years ago
Not from U15. All the Data line should be pulsing pretty much constantly. Different chips drive it at different times.
#41 5 years ago
Oh crap! Could a memory chip have anything to do with it? Some have data lines. Well U1, 7, and 8 does....
I maybe off on my thinking, but what is the best way of tracking down the lack of pulsing?
#42 5 years ago
Anything on the data line could cause it. Ram, rom, pia, etc. Or stray solder.
You could try taking out all the chips, and measuring resistance from each Data like to ground, see if this one has a different reading. If so, you'd know it's not one of the socketed chips.
$ 5.00
$ 18.95
$ 5.00
$ 9.00
Cabinet Parts
Third Coast Pinball
Third Coast Pinball
2,600 (OBO)
Massapequa, NY
$ 69.00
Pinball Pimp
Metal-Mods
$ 85.00
$ 69.00
Pinball Pimp
$ 22.50
$ 9.95
2,000 (OBO)
Li, NY
This page was printed from https://pinside.com/pinball/forum/topic/bally-35-boot-issues-led-locked-on and we tried optimising it for printing. Some page elements may have been deliberately hidden.
