(Topic ID: 192112)
(Fixed) Bally -35 board switch issue.
By JT-Pinball
  • 44 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Quench
    #1 4 years ago
    Tonight I am working to bring an old Bally -35 back to life. I intended to just have this be a spare board to have for the next project, as it didn't look too tore up by alkaline damage.
    So here is my issue. When I have this board on bench it boots up fine. When I put board in game known good game it boots fine. But after it boots it dose not seem to function it attract. Stuff on game seems slow or just stops. I have had this issues on boards before with bad jumpers settings or a break in jumpers. I have checked and verified that is not issue. Other issue is that the it is causing solonoid Q9 to fire repeatedly. Seems to just fire in sync in one second pulses.
    So here is what I have done.
    Replaced all header pins
    Replaced U2 socket
    Installed NVRam
    Installed new PIA in U10 and U11
    Replaced bad diode at CR41
    Using know good game Roms at U2 and U6
    Guess the next step is to trace back that solenoid strobe to U10 and see if I have a resistive short??? Or just replace the socket?
    #2 4 years ago
    short some where. Mpu probably
    #3 4 years ago
    Quoted from jj44114:
    I think so too...
    #4 4 years ago
    Have you made any progress with this?
    Do you have a device to measure frequency?
    In terms of the attract mode slowness, make sure the following signals are in spec:
    Pin 18 of U10 should have a 120Hz signal (Zero Crossing Interrupt)
    Pin 40 of U11 should have a 317Hz - 320Hz signal (Display Interrupt)
    It's unlikely but possible that the solenoid Q9 transistor repeatedly activating could be related to the slowness issue you've got with timers being out of whack.
    What game are you testing it in?
    Have you tried another 6800 CPU at U9?
    #5 4 years ago
    Thanks for your reply Quench.
    Quoted from Quench:
    No. I have had a crazy last few days at work and not been able to focus on this.
    Quoted from Quench:
    Yes. My DMM will do frequency. I will pull the board out of the game and put back on the bench and run the test above.
    Quoted from Quench:
    Hot Hand
    Quoted from Quench:
    No. I swapped the PIAs for new ones. Once I got board to execute the program and pulse the test lead with the Leon's, I assumed I had a good U9.
    #6 4 years ago
    Quoted from JT-Pinball:
    You'll need to leave the board in the game to properly measure the Zero Crossing detection circuit because it's derived from the unregulated 43V DC solenoid supply line.
    Ok, solenoid transistor Q9 continually activating tells me the MPU board is sensing the left side kicker switch as being stuck on. It's trying to eject a "stuck ball" from the kicker.
    I was helping a fellow pinsider repair a battery corroded board 6 months ago - he got the board booting to attract mode but it would stop at that point (displays working, but no lamp animation/switch response). Turned out to be his CPU causing it, which is why I mentioned it.
    #7 4 years ago
    Quoted from Quench:
    True.
    Quoted from Quench:
    I forgot to mention I have J2 and J3 unplugged from MPU.
    Quoted from Quench:
    I'll swap the CPU and see if that helps first.
    #8 4 years ago
    Quoted from Quench:
    Pin 18 U10 is 119.6hz Pin 40 of U11 is 319hz
    #9 4 years ago
    Swapped the CPU. No change.
    #10 4 years ago
    Ok, if you hook up connector J3 to the MPU board, can you get into test mode?
    #11 4 years ago
    I had it in test mode before I started switching things around. I will have to see when I get back to the game this afternoon. Thanks Quench.
    #12 4 years ago
    No worries.
    I'd be interested in knowing if the lamp/display tests run at normal speed.
    Also if you can get to switch test mode, disconnect J2 and J3 from the MPU board live and see if the MPU board thinks any switches are closed.
    #13 4 years ago
    Will not enter test mode. After I changed U9 now it plays the into music over and over.
    #14 4 years ago
    Take a close look at the U9 socket.
    #15 4 years ago
    What's happening on the displays?
    Check the CPU socket as jj44114 mentioned.
    If you set all the 32 dip switches to OFF, does the game start in factory test mode?
    Might be time to post some very clear pictures of the front and back of the board.
    #16 4 years ago
    I'll see if I can get in to factory test mode. The more I read thru other post with similar issues it looks like to me it is probably a socket issue with U9 or U10. They are the old flat black Augat. I took a short video of it but can't figure out how to post. I'll pull board later and take some pictures of it. At this point if I take it out again I may just replace sockets at U9 U10 and U11. Those sockets just suck to get off the board. Even when you have a Hakko FR300.
    #17 4 years ago
    Try adding/melting a drop of new solder on each pin first. It makes it easier for the solder sucker to effectively melt the old solder for removal.
    #18 4 years ago
    pry up the plastic from the sockets(U9 for sure, you might see the problem on the underlying pins) with a small screwdriver. Heat each pin from the base of the pin. They are pretty easy to pull out one by one.
    #19 4 years ago
    Some IC sockets used on bally boards have contacts with leafs that like stick to the pad on the top side of the PCB when vac desoldering. A trick I would use is desolder out the hole clean and while the leaf is still hot, use the tip of the desoldering gun to gently push the lead back up towards the top side of the board. They usually fall right out or will not be stuck to the top side.
    The black closed frame sockets with paper underneath, pull the socket frame off and then they desolder pretty easy
    The orange closed frame ones desolder pretty easy with a FR300 in good working order.
    If the frame can come off, it do it. Usually makes desoldering easier. Sometimes you cant tho.
    #20 4 years ago
    #21 4 years ago
    #22 4 years ago
    Thank everyone. When I desoldered U9 I had 2 traces pop up on the board. They still tone out. I think I will solder them together at the pad and solder on the SIP socket. Then add some conformal coating to hold them.
    #23 4 years ago
    To be honest, looking at your board pictures I rather doubt that U9 socket was your issue.
    Quoted from Quench:
    I think we need to revisit this. When I check in emulation with the kicker switch stuck closed, the game runs dead slow in attract mode and activates the Q9 transistor for the kicker solenoid repeatedly once a second which sounds like your original issue.
    I can see someone has replaced diode CR41 on the MPU board which is on the switch return line signal that the kicker switch lives in the switch matrix.
    Repair those two lifted traces and install a new U9 socket then put the original 6800 CPU back in.
    I don't know if you saw this thread below but you're likely to have similar board issues. We should do some resistance measurements on the switch return signals on the MPU board.
    https://pinside.com/pinball/forum/topic/tilt-immediately-at-game-start-but-no-stuck-switches
    #24 4 years ago
    With the MPU board on the bench i.e. disconnected from game, set your multimeter in resistance mode (at the 200k ohms scale if your meter isn't auto-scaling) and measure the resistance between:
    a) J2 pin 8 and J2 pin 9 (i.e. one meter lead on pin 8, the other meter lead on pin 9)
    b) J2 pin 11 and J2 pin 12
    c) J2 pin 14 and J2 pin 15
    Now measure the resistance between these signals on the 6821 PIA chip at U10 between:
    d) pin 10 and pin 11 (i.e. one meter lead on pin 10, the other meter lead on pin 11)
    e) pin 13 and pin 14
    f) pin 16 and pin 17
    Report all the readings.
    For reference, two of my boards on the bench measure around 95k-100k ohms at all these locations.
    #25 4 years ago
    Hey Quench hope all is well for you today!
    Ok
    Quoted from Quench:To be honest, looking at your board pictures I rather doubt that U9 socket was your issue.
    Yes. I am following this thread.
    #26 4 years ago
    Try and report the readings requested on post #24 above. You can do the readings before repairing the U9 socket since U9 is not part of that circuit. I need to head out so we can follow up later/tomorrow.
    #27 4 years ago
    Quoted from Quench:
    My meter is auto scaling.
    a) J2 pin 8 and J2 pin 9 3.4M
    b) J2 pin 11 and J2 pin 12 115k
    c) J2 pin 14 and J2 pin 15 115k
    d) pin 10 and pin 11 3.5M
    e) pin 13 and pin 14 112k
    f) pin 16 and pin 17. 102k
    Ok. So I glued down the traces with gorilla glue and then sealed them in conformal coating.
    I took readings and had a open line at U10 P13 I reseated U10 fixed open line and got above readings. For giggles I put board back in game, this seemed to fix sound problem. Game is also running faster. Still won't enter test mode. Q9 still pulsing and I can see it flashing as soon as it goes into attract. I have disconnected sdb but have connected my sdb output testers and can watch it flash. It pulses in rhythm as soon as mpu boots.
    So I am looking at the -35 schematics. Looks like I have a short somewhere between PB 0-1 and PA 0-4 or into the zero crossing signal coming into P18. Well this is my guess based on schematics. I think I should change U10 socket? No?
    #28 4 years ago
    Thanks quench
    #29 4 years ago
    Don't change the socket yet. Report the resistance readings first.
    #30 4 years ago
    Open your quote
    #31 4 years ago
    Oops, sorry I was in a rush.
    The repair looks good. I presume you have solid connection between the top and bottom traces at those two pin holes at the U9 socket where the traces lifted?
    The switch return line shown on the schematic as "I1" (where the kicker switch signal comes back on) is the PB1 signal (pin 11) of U10 and it goes to a 56K resistor (R45) which pulls the signal low. Your original symptoms and very high resistance readings at pins 10 to 11 on U10 tell me there is an open circuit on this PB1 signal to that resistor or the resistor itself is open circuit.
    See the picture below showing the location of this resistor. With your meter on resistance mode, do you read 56k ohm across that resistor?
    Pin 11 of U10 goes to the left side of that R45 resistor. Do you measure an open or short circuit between these two points? If it's open, follow the traces on top and bottom of the board between these locations to try and work out where it's open circuit.
    #32 4 years ago
    Quoted from Quench:
    Oops, sorry I was in a rush. Lol! No worries.
    Quoted from Quench:
    Thank you! It took a minute to fix that without jumpers. No room to try stick a solder stich in the socket. I had to tin the end of that trace under magnification, stick it to broken end or the plated hole under the socket. Smoothed it out, put a dot of flux there and soldered it from the back. I have good continuity between the socket and board. Board boots!
    Quoted from Quench:
    The switch return line shown on the schematic as "I1" is the PB1 signal (pin 11) of U10 and it goes to a 56K resistor (R45) which pulls the signal low. Your original symptoms and very high resistance readings at pins 10 to 11 on U10 tell me there is an open circuit on this PB1 signal to that resistor or the resistor itself is open circuit.
    Let me get the schematics and I will look at that and follow thru and report back! Thanks Quench
    #33 4 years ago
    Not sure why pictures reattached.
    #34 4 years ago
    Ok so resistant at R44 is 3.2M. Other are 56k.
    #35 4 years ago
    Bang! Changed R44 as you suggested. Game enters attract and plays as it should! Quench thank you!
    I will mark as fixed. So wonder what happened? Resistor blew for some reason caused diode to blow? I replaced diode but should have checked to make sure path to ground did not short?
    #36 4 years ago
    Interesting effect that resistor had. The 56k resistor is a pull downs on the switch returns.
    Usually resistors are visibly burned open or that have some kind of mechanical failure. Like a broken lead right where it enters the resistor body can be tough to visually spot.
    #37 4 years ago
    I have started do most work under magnification. Helps see the detail. I didn't notice any physical difference in the resistor. Just the different resistance measurements.
    I had a display issue once on a stern MPU 200. One digit out on all displays randomly. It looked good. But in the game it pulled open just enough as barakandl said where the lead entered the resistor body. I traced the path back with schematic and was reflowing things. Low and behold the lead moved and fell out. New resistor and displays have been working since.
    #38 4 years ago
    Great stuff!
    Is the test switch on the coin door working now?
    Quoted from barakandl:
    Since the resistor couldn't pull the signal low, the open circuit signal must have been closer to or in the high logic threshold of the PIA sense circuit. It lead to all switches on that row being read as active which the kicker continually reactivating was the clue.
    Trivia: Hot Hand has a secondary switch location within the matrix that spots the "Ace", but no switch on the playfield is assigned to it. Makes me wonder if that white standup target next to the spinner was originally put there to spot the Ace but was deemed too easy...
    #39 4 years ago
    Quoted from Quench:
    Great stuff!
    Is the test switch on the coin door working?
    Yes. Game functions as it should. Only one difference I noticed and maybe you Quench or barakandl can help me understand. I took my NVRam out of the stern MPU -100 I had in the game. I had played maybe 300 or so games on that MPU with the NVRam. But when I put it in the -35 the settings were erased? I guess I thought all the audits would stay. So my next question is is to put that NVRam back in the original MPU will the setting and audits return?
    Quoted from Quench:
    I have had this game for a long time, and were looking at these schematic long before I had any understanding. But now that you point that out I see it instantly on the switch matrix. Lol! Thanks for the trivia Quench
    #40 4 years ago
    The games probably use different parts of the memory for different things My test bed is a Black Pyramid a lot of times. When i throw different game ROMs in after being played as BP, usually a lot of the audits have ramdom crud in them. BP must use certain areas of memory for gameplay stuff while other games use that spot of memory for an audit.
    Will they return.... Maybe? The fm16w08 will hold the memory unless the other game wrote over top of it.
    #41 4 years ago
    Ok. So it must be driven on the board. No? This -100 had my original game roms for Hot Hand the 9316A and this NVRam. I put the 9316A Roms and the NVRam in this -35 and back into Hot Hand. So the different board must address memory differently?
    #42 4 years ago
    Actually there's two unused Ace switches - the two unmarked/unused switches between the "Jack" and "Ten" on row I5 both spot the Ace.
    This is rather unusual because the audits are stored in the same locations.. Even a lot of the audit locations are common between Bally and Stern MPU-100 games. I'm not sure about the later Bally-35 games and think Stern may have changed things on their MPU-200 games.
    #43 4 years ago
    I just shipped out a MPU for Stern Magic. It got tested and then play tested in Black Pyramid. The FM16W08 come blanked out so all the audits are 00 on first boot. Play test good, install Stern Magic and more than a handful of audits have crap in them. One is always 300,000 and some others like 33,000.
    #44 4 years ago
    I'm not sure about the later Bally-35 games (Black Pyramid might have changed locations). Stern changed audit locations on their MPU-200 games.
    Same ROMs on a Stern MPU-100 or Bally-35 board should store the audits in the same location though - addressing to the U8 RAM is the same on both boards.
