Hi - got a -35 on the bench. U15 was buggered so replaced that and the board booted but after the 7th flash when it should go to a half LED the LED either locks on (like an 8th Flash) or Resets and then goes in to a reset loop for a few cycles then eventually locks on.
The Reset voltages U9 Pin40 always stays high 5.2v
VUA stays good throughout
Replaced all socketed chips but no change
Very minor acid damage along the bottom earth line but generally much much better than most I've seen.
IRQ line is good to U10 U11 and seems to stay good through the cycles
Where to start? Never has this before...
