Installed a whole kit but it had the bux85g in it. Worked for 2-3 minutes now I can only get 8vdc out of the HV section. Any ideas what to check?
Attached is a photo if you want to check my work. I did use mica and a new plastic screw thru the bux 85g.
The original HV section did not work, it just fed the full 230v to the displays thus ruining all of them. It was visually perfect however, no burn.
