From what I can see, the difference between the bally E -122-125 and the E-122-131 transformers is that the -125 has an output of 7.8VAC at winding 4 whereas the -131 has an output of -9.2VAC at winding 4.
This voltage is then rectified for the switched illumination BUS to 5.4VDC for the -125 and 6.5VDC for the -131.
My question is this:
If I run only LED and not incandescents can I use the easier to find -125 and run 5.4VDC Switched illumination BUS in a game that would normally have 6.5VDC?
