In a recent post, I compared some different types of pinballs using a Proscope HR microscope. It showed interesting differences and generated quite a few responses. A pinsider supplied me with some brand new premium brand balls for comparison testing. I've made a new post here, with the photographic results below. The test was performed using my Williams Funhouse machine in average condition. Each ball was marked with a small scribe to identify it. The Funhouse machine is a 3 ball game and was set to 3 balls per game. It was played 100 times and average game time was 4 minutes each. Photographs and photomicrographs were taken at 50X and 100X magnification before and after use.
Tested were the Pinbits Premium Chromium carbon steel balls (hardened), Marco Silverjet Premium carbon steel balls (hardened), and Pinball Life Premium Ultra-Gloss (carbon core). Note that of the three, only the Pinball Life Premium balls are listed as suitable for magnetic games such as TOM, TOTAN, TZ, etc. This suitability was not tested. Also note that no other specifications such as roundness or weight were tested.
My observations were as follows: As brand new balls, the Pinbits seemed the most glossy and smooth, truly like mirror. The Marco were nearly as glossy as the Pinbits, but priced a little higher at time of writing. The Pinball Life balls were fairly glossy and priced very competitive, but under a microscope one can see small uneven textures where dirt "might" get trapped. However, after 100 plays, all the balls had about the same number and depth of scratches from a micro view. From a macro view, they all became very similar in appearance. It would be hard to tell which is which, if not for the scribe marks I had made from the start. If I had to pick the smoothest balls, Pinbit's or Marco's had a slight advantage over the Pinball Life premium. But once they all had been used for a while, that advantage dissipated and meanwhile Pinball Life's ball construction reportedly has the important resistance to magnetism that is important for so many different games.
I'd like to thank everyone for their interest and input in this small study.
