(Topic ID: 278085)
Ball releases without advancing ball count
By Jazorf
1 year ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by timkirk
#1 1 year ago
I have a couple machines that will very occasionally release the ball from the outhole ( after draining) without advancing the ball count. Basically they will act as if there was no score and ball is being returned. I guess my question is what is it that registers that first score of a ball? My thought is that the problem probably lies there, either it’s sticking or the gap is slightly off. I know that this happens once in a while on my Williams Paddock and Strike Zone. it may have happened on Spanish Eyes too. Any thoughts?
#2 1 year ago
With Williams and Bally it’s called the ball index relay. On gottlieb machines it’s called 1st ball relay.
#3 1 year ago
Quoted from Jazorf:
Does it happen when no points are scored? If so, that's the correct behavior on Williams machines.
#4 1 year ago
No, that’s why I said it acts “as if” no points are scored. It could be a record high scoring ball and then it will kick it back out. I’ll be checking the ball index relays when I get home. I’m sure it’s a very minor adjustment as it only happens once in a while.
#5 1 year ago
Quoted from Jazorf:
OK, so this is the area on Paddock you want to check, starting with that M/B on the Outhole relay. Note that some score motor sw. are involved.
3 months later
#6 1 year ago
I saw your post when I was researching a similar Williams ball count issue. Not sure if you are experiencing the same issue as me, but it sounds like the same intermittent issue I had. Here's how I resolved mine: https://pinside.com/pinball/forum/topic/williams-ball-count-player-count-issue-solved#post-6051476
