(Topic ID: 277321)
Ball Pull Removal Help - Gottlieb Cowpoke
By KDMpinball
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by KDMpinball
#1 1 year ago
Hello all, I have a Gottlieb Cowpoke from 1965 that I received from my father back in 1995, he purchased it years earlier around Eau Claire, Wisconsin. It's in Dallas now. I have kept it working and it still does, however the plywood on the backglass was peeling. It's been on my list to fix for 25 years (wow) and I finally have started to fix it up by replacing the wood and painting it.
The inside is dirty so I figured I would do that as well. Small problem, how does one remove the striker tip from the ball pull? I tried to rotate it and pull but no movement. I stopped so I don't smash it up. See pics.
Any help on how to remove it?
Thank you.
#2 1 year ago
Quoted from KDMpinball:
Because the end is mushroomed ? Dremel, grind it smooth.
Or cut it off and get a new shooter rod.
#3 1 year ago
Thank you.
[quoted image][quoted image]
I've used a good file and in a couple minutes smoothed it down for removal.
#4 1 year ago
Thank for your replies, appreciate it. I decided to start sanding while waiting and I nudged the bar and it popped off. There is a plate that secures the assembly on the inside and the notch in the plate narrows to hold the bar in the machine. See pic.
I assumed it was the tip without looking further.
Hopefully this helps someone else.
$ 109.99
The EM Scientist
$ 5.95
The EM Scientist
Cabinet Parts
Space Coast Pinball
$ 1.95
Various Novelties
Pinball Wheezer
$ 36.95
Tools
Magaro Machines
