50's Williams Ball Lift Assembly removal?
(Topic ID: 218642)
By PinballFever
9 months ago
  • 18 posts
  • 4 Pinsiders participating
  • Latest reply 9 months ago by PinballFever
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 9 months ago
50's Williams. I've never removed one of these. The screws are undone but the metal holder won't budge. The metal "collar" on the front seems to be riveted to the metal holder or something. Does it unscrew?
IMG_20180606_194457964_LL (resized).jpgIMG_20180606_194016129_LL (resized).jpg
#2 9 months ago
Is that Grand Champion still Bruce? Answer: YES! lol - I see now you linked it...
I can't recall doing one like that, but I'm sure I have at least one game from that vintage cabinet I can look at later and see if it rings any bells on how that particular version comes apart...
Sean
#3 9 months ago
I have two projects I'm working on right now...one is a 51 WLMS Shoot The Moon, and I thought maybe these two games are the same - but alas, they used the "mini-beehive" type on STM, and looks like they switched to the GC style with Paratroopers in 52.
I definitely have project games from that era with the GC type, but none of those are apart right now. I'd assume they just changed the outer piece, and they attach the same, but I'll try to check it out later. I vaguely remember the STM one being a bastard to get apart...I'll likely recall more about it when I get it all in front of me.
Sean
#4 9 months ago
From the mark on the front collar Bruce it looks as though someone has already tried to apply, what we call a stilson wrench, to the front collar. Have you tried doing this with protective cloth, while holding the inside fitting, to avoid any damage. I am probably wrong but the knurled fitting inside almost looks like a 'gulmite' fitting?? Ken Layton would know for sure.
#5 9 months ago
Quoted from Stoomer:
YES it is Sean! It's my *only* grail pinball that took over 40 years to find but better late than never!
Much appreciated.
Bruce
#6 9 months ago
Quoted from wayner:
Not yet I'm afraid to break something that might be irreplaceable Wayne.
Quoted from wayner:
It looks kind of like a gulmite screw but I'm not sure either. Here's a closer shot of it. I also found a Pinside thread about gulmite screws. https://pinside.com/pinball/forum/topic/tamper-proof-boltslook-familiar
Sent a PM to Ken Layton about this thread.
#7 9 months ago
Quoted from PinballFever:
On closer look at your latest pic Bruce that does not appear a Gulmite application. Out of interest here is a set of Gulmite drivers on ebay at the moment-ouch $US600!
ebay.com link » Gulmite Crown Head Security Screw 5 Piece Screwdriver Set
#8 9 months ago
Much appreciated.
Bruce
I did finally make it out to the barn last night, but none of the games I have that employ that style ball-lift were easily accessible, and none had that assembly already disassembled. I meant to look in my parts bins when I got back to the house for one of these, but my absent-minded brain lost that idea on the way back. Welcome to my world...
I also checked my Shoot The Moon, which is all apart as I said, and that uses the mini-beehive style Williams used on earlier pins. That one definitely threads on...but that style is attached on the inside with a big nut...way different than this "backing plate" we see on your GC.
Thinking back I guess I've never done a Williams game that has this style...I don't like the looks of that - it looks pressed or stamped on. But I can't imagine them doing that with the cabinet in between, so I think it's more likely that fixture was stamped/pressed when it was off the machine, and since the style right before this was threaded, hopefully this one is too.
If it's not one piece all the way through, and threaded somehow, there should be a gap/seam inside the channel that the rod slides through. If you can find that, then at least you'd know they come apart.
You could also call Steve Young...he may have some insight on this - I know he's got games like this, and maybe has the parts manuals that potentially also show the breakdown of this assembly.
I look in my parts bins...maybe!! LOL...if I can keep that thought in my head that is...
Sean
#9 9 months ago
Good advice. I just called Steve and he told me the collar should just come out but may be rusted stuck inside. He told me to carefully tap the collar until it loosens.
Ken Layton responded to my PM with almost the same advice. Says to grab the inside bracket and keep wiggling, spinning it while pulling it inside the cabinet.
Will try both when I'm home.
#10 9 months ago
Also Steve Young told me that this old style ball lift assembly would be in the online WMS 1960 parts catalog. (I've read this online parts catalog before but didn't think to check for this assembly)
Page 54: It looks like the "collar" is one piece that goes through the cabinet. No part number for it though.
http://www.planetarypinball.com/reference/partsmanuals/WMS_Parts_1960/index.html#/54/
#11 9 months ago
Here is the old "ball lift rod" that was being used in the game and the correct lift rod parts that will replace it. It makes sense that the "collar" would be as rusted inside as the old rod is.
#12 9 months ago
Ahhh I see it now in the parts catalog.
This is one piece. (not two pieces like I originally thought) The "collar" is the part of the ball lift assembly that you insert in the hole from inside the cabinet. It will have to be removed from the inside so Ken Layton's and Steve Young's advice makes sense.
#13 9 months ago
Over the years, the wood may have swollen thus making this assembly hard to remove.
#14 9 months ago
Got it. I learned something new here. Twisting and pulling the frame wouldn't budge it. I used a hammer with wood to tap the front of it hard like Steve Young suggested and it budged.
There is a thin metal ring inside the hole where this ball lift assembly goes through then it screws into the cabinet.
Good to know how to do this now.
I also learned something new about gulmite screws that I can keep my eyes out for, thanks Wayne.
Thanks for the help guys.
#15 9 months ago
Ah-ha!! It goes all the way through!! Of course...
I'm glad you got to the bottom of it...I have done a game like this now that I see it...although I can't recall which one. I remember the way the rod comes apart better than the sleeve removal for some reason...
Thanks for posting the solution...
Sean
#16 9 months ago
Yeah. The "Ah-ha!" moment for me was when Steve Young told me to check that part in the 60's WMS parts catalog. Good suggestion to call him because I thought it was a mini "beehive" similiar to the beehive on the shooter rod.
Thanks to Robin and Pinside for making it possible to not only find the solution but to post it too.
#17 9 months ago
Take a Scotchbrite pad to the inside of that metal ring to make it easier to install/remove that ball lift again in the future.
#18 9 months ago
Will do. Thanks again for the help, Ken. Much appreciated.
$ 6.00
German-Pinball-Modular
$ 9,500.00
Bright Lights Pinball
Displays
GermanGamingSupplies.com
$ 58.00
$ 5,799.00
Classic Game Rooms
$ 48.00
$ 44.99
Lee's Parts
$ 69.99
$ 3.00
Doc's Pinball Shop
$ 36.99
$ 69.99
$ 109.99
$ 24.95
Hookedonpinball.com
$ 109.99
$ 24.99
Lee's Parts
$ 48.00
Metal-Mods
$ 69.95
$ 40.00
£ 29.00
PinballToys
