Issue with both ball kickers on a space shuttle. When I ground the tab on the transistor they both fire no problem. So i assumed it was the switches, I checked continuity from the switch to the connector in the backbox, tested good. Checked continuity from the other side of the connecter to the IDC Connector on the CPU board, tested good as well. So I plugged the connector back in and tested continuity from the switch itself directly to the IDC connector on the motherboard and it also tests good.
So I'm kinda stumped really, they used to work before I pulled the playfield out a year ago to shop the game but now that its back together again they don't activate. The coils fire when I short the transistor and the wiring to the switches is good. I don't know where to look now.
