Hi
I have an issue on a Stern game with balls failing to roll down the trough. Typically when a ball is kicked up the remaining 3 do not all roll all the way down the line.
I know this partially is due to balls getting magnetised. I, however, recently replaced balls with low magnetisable ones. And the problem went back again pretty fast.
I have tried to adjust the switches to only go as high up as necessary. But they are pretty much stock in place. And I have not gone into bending the lever.
Any suggestions on what to do?
