I've struggled with the cannon on my AC/DC Pro for quite awhile, not firing. I thought it might be a bad sensor or as GatorDad pointed out, screws protruding from the swing arm.
But what i'm noticing is that the ball is getting stuck under the cannon... and when I take examine it there about a quarter inch of play, meaning I can lift the cannon about a quarter of an inch and the ball passes through.
I then noticed that there is some sort of plastic washer underneath where the cannon mounts to the motor post with the 4 screws. That plastic washer seems to be just laying there loose and not doing anything. Is this factory or did someone add it?
My thinking is that the cannon is sitting too low, is catching the ball, and is also making the swing arm pass through the opto incorrectly. If I move the cannon post up an down it also moves the curved opto arm up and down. Hope this makes sense. I can take a pict if needed. Thanks!
