(Topic ID: 114998)
Ball Eject problem on ToTAN
By DnDPins
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by LTG
#1 4 years ago
It seems like a mechanical issue with the Harem ball eject arm. I checked the plunger, coil and springs and fired the solenoid in test mode. It fires but the kicker arm does not recede back. The mechanism seems stiff. Have any of you had to actually take apart the ball eject assemble before. Is this one of the few places on a pinball to use oil?
Thanks,
Dave
#2 4 years ago
Don't use oil. Take apart and clean and check for worn coil sleeve and stuff first.
LTG : )™
#3 4 years ago
I had similar problem on my Totan on the left orb kick out. You can see step by step with pics what I documented here :
http://www.pinballrevolution.com/threads/totan-you-break-you-buy.359/
#4 4 years ago
Quoted from mwong168:
Good advise for any game with a kicker problem.
#5 4 years ago
Thanks to all for the help. I took apart the arm mechanism and cleaned and it works like brand new now.
#6 4 years ago
Im having the same exact problem.
I took apart the arm mechanism and cleaned it very well, squeakily clean. I replaced the solenoid and the sleeve and still no luck.
When the ball rolls into the lock area the ball registers and the machine makes the sound that it normally makes when it is about to eject the ball but the solenoid never activates. All of the solder points look good to me. Not sure what to do next.
#7 4 years ago
Quoted from balls:
Grab meter. Check continuity of each wire from the coil to the driver board.
LTG : )™
Trade
Machine - For Trade
Baltimore, MD
