(Topic ID: 299868)
Bad Switch? Magic City
By Tonup69
1 year ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Tonup69
#1 1 year ago
I’ve been having intermittent trouble with a switch on the Target Relay on Magic City. The video sums it up. I’ve cleaned and adjusted it several times, but it continues to make intermittent contact. I can touch it and it will chime and score correctly (yeah, I know, don’t touch it). Should a replace the switch bank? What else can I do to get it working?
Looks like I can’t add a video. Switch is on the end of the target relay bank. I’ll try a photo later.
FYI - the issue is the roll over ore target won’t score or will intermittently.
#2 1 year ago
I have had switches that required filing, usually large tungsten contacts that were corroded/pitted. Needed to use a metal file, the usual flexstone didn't cut it.
Also had cases where a contact was in the switch blade but had become loose. Have to re-peen those on a metal surface with a few hammer taps.
Another case is where the switch blade is broken inside the stack so you can't see it.
#3 1 year ago
Quoted from dr_nybble:
These all sound awful - but i guess I can start with the metal file. Trying not to take the stack out, if i can help it.
#4 1 year ago
If it works reliably when you push it, but only intermittently when the ball does it, could it be that the switch doesn't have enough over travel or wipe? Ideally switch contacts like to wipe across each other rather than just touch. The long blade contact should push back and wipe across the short blade contact.
/Mark
#5 1 year ago
Quoted from Tonup69:
Rather than dismantling the stack, you can put a meter ( machine disconnect from the power outlet) on one end of the suspect switch blade to the contact to bridge it and see if you have continuity. Obviously, the other side of the switch needs to be open or you will likely get a false reading.
#6 1 year ago
Quoted from MarkG:
/Mark
I agree - that's why I readjusted it as close as possible - more slide. That didn't help either. I will lift the rely and switch stack so I can get a closer look at this switch - sometimes that seems to help (i.e. I can see something I missed).
One thought - I need to check the center target - maybe it is stuck on? I didn't do that yet.
3 weeks later
#7 1 year ago
SOLVED - there was one switch on the Coin Relay that was rubbed down to nothing - i.e. no ball on the end of the switch for contact. I used a method I have seen here - solder a ball to the end of it - i.e. replace it with solder. filed it a bit and it works great! Not sure how long the solder will last, but all of my problems solved with the center target, bonus, start up - everything was through this switch. Thanks for helping me troubleshoot.
$ 109.00
Playfield - Plastics
Starcade Amusement
Plastics
The Pinball Scientist
Other
$ 5.95
Protection
Various Novelties
Pinball Photos LLC
Various novelties
£ 125.00
Retro Electro Designs
$ 9.00
Led
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/bad-switch-magic-city and we tried optimising it for printing. Some page elements may have been deliberately hidden.
