(Topic ID: 262208)
Bad Girls Club "Set Up Your Balls"
By fatality83
1 year ago
  • 41 posts
  • 17 Pinsiders participating
  • Latest reply 3 days ago by Agent_Hero
#1 1 year ago
Thread dedicated for Bad Girls pinball machine. Here's a place to share game play tips, high scores, repair questions or just talk about the hotties on the backglass.
#2 1 year ago
No club before now? Shoot.
Well, I'm making replacement windows for a fellow Pinsider. If anyone needs one, the will be in my Pinside store soon. Also will have replacement 2-way mirror plastic as well.
#3 1 year ago
Oooh finally. Love my game, bought it cheap but has no sound. Tried to figure out but thinking just to send in sound board to Clive.
#4 1 year ago
I just completed a full rebuild of mine. I had to improvise slightly for some parts which are no longer available. For example, the pop bumper bodies aren't available from PBR with the silver/chrome finish. I utilized self-adhesive aluminum trim to obtain a nearly identical finish compared to the originals.
#5 1 year ago
#6 1 year ago
Quoted from JodyG:
Well, I'm making replacement windows for a fellow Pinsider. If anyone needs one, the will be in my Pinside store soon. Also will have replacement 2-way mirror plastic as well.[quoted image]
I would definitely be interested in both....and your in Lancaster this can't get much better lol. I am in york so wouldn't have to ship them
#7 1 year ago
Quoted from extraballingtmc:
Couple things you can check is first make sure all ground mods are done. Make sure sound board is recieving 5 volts. Should have a red LED on board. Maybe swap the board out for another if you have a spare to make sure it is the board. I also know there is some information on sound issues with system 80 b on clays guides
#8 1 year ago
Quoted from SeymorGoldfarbJr:
I just completed a full rebuild of mine. I had to improvise slightly for some parts which are no longer available. For example, the pop bumper bodies aren't available from PBR with the silver/chrome finish. I utilized self-adhesive aluminum trim to obtain a nearly identical finish compared to the originals.[quoted image][quoted image]
Looks great makes a huge difference!
#9 1 year ago
Any ideas where to get replacement mirrors for the cabinet?
#10 1 year ago
Quoted from fatality83:
Absolutely! I have a set going to the donor today to verify fitment, so I can get you one early next week if you like.
#11 1 year ago
Plexiglass mirror is pretty cheap if you get a full sheet of it. I contemplated selling them, but that size becomes a hassle to ship. You may be able to order it precut to size from a place like Canal Plastics. I am not sure how thick they are on Bad Girls, but Canal sells a 24"x48" sheet of 1/16" mirror acrylic for $60 plus shipping. Slice it down using a fine tooth plastic blade on a table saw. Then you can round the corners off by hand.
#12 1 year ago
JodyG did a fantastic job reproducing the playfield window and playfield mirror for Bad Girls, identical to the original. Very fortunate that these parts are now available especially since they’ve been out of circulation for years now. Included some pictures. Thanks again Jody!!
0A4E00D9-A01C-4643-97BB-EB3A273C93CF (resized).jpeg858537BD-CFA8-4399-9E54-2E50BCCB61DB (resized).jpeg8A656B85-557A-4A54-9488-E5BFD48EB60E (resized).jpeg
#13 1 year ago
Hello, I bought a Bad Girls at an auction and the rent a-bums they had literally ripped the left front leg off and bent the right front leg while transporting it.
So it went into storage over ten years ago because I'm not a pinball guy and I was tired of getting the stinky end of the shaft from the local hacks.
I've recently started getting my other machines working. I've kept this one for last because of the amount of work it needs and I needed a couple working machines under my belt to boost my confidence before tackling this task.
I found out what battery leakage was. I started looking on the web for info. I removed the battery, replaced a couple of the larger caps, replaced a couple coils, a blown F-10 fuse, new cord and freed up the drop targets. Crossed my fingers and powered it up.
It came to life and seems to function as it's suppose to except alot of burnt bulbs. Now that's it's working I've been inspired to work on the cabinet. I fabricated some brackets for all the front inside corners, modified some new bally leg mounts to fit, broke out the wood clamps and a bottle of gorilla glue. The clamps came off today and I started working with the plastic wood. I'll try to upload some pics when I'm done sanding airbrushing and putting the mirrors back on. Then it's onto cleaning up the play field, LED's, rubbers and fabricating a bracket to hold color changing LED's for the back box instead of that florescent fixture.
I need a little help finding out what kind of battery and holder I need to put back on the board. Also there are little rubber stoppers on the top of the post instead of acorn nuts. Is this normal?
thanks
Committed to this machine or Should be committed
#14 1 year ago
Someone needs to make a custom instruction card for this game. I may try to learn how but hoping someone with photoshop skill can pull it off
2 months later
#15 1 year ago
Seems like most suppliers are out of stock but does anyone know where to get a new sound board for bad girls?
#16 1 year ago
Quoted from JodyG:
JodyG Those are beautiful. I applaud you for putting all this work into remaking a part for one of the least desirable titles (unfairly so) of the era.
I love how Bad Girls is so unmistakably and blatantly 80's, more so than any other pin. I made this gameplay video of mine about a year ago. Including cool 80's style intro and some interesting facts about the game. Enjoy!
#17 1 year ago
Top right flipper stopped moving on my friends Bad Girls. Only the top right.
Anything I should be looking for to get this flipping right again?
#18 1 year ago
Quoted from vassq:
Check the flipper EOS switch and cabinet flipper switch.
1 month later
#19 11 months ago
I had my Bad Girls now for 2 years and it's a great game.
2 months later
#20 8 months ago
I picked up a Bad Girls recently and was missing the background music. I wasted some troubleshooting time thinking this sound board was unique due to the number MA-886-717. After a brainstorm eventually hit I realized despite the number its identical to to main board in Bone Busters and of course it tested fine in Bone Busters. The System 3 sound board MA1629 also looks to be identical and is still available NOS although I have not tested one out yet to confirm. My missing background music ended up being a bad driver board. I thought I would put this here in case it helps someone else one day.
#21 8 months ago
Bad Girls Owners- if you haven’t already rated your game on Pinside, please take the time to submit a review- only need three more reviews to get Bad Girls back on the Top 100 list!
#22 8 months ago
Quoted from JodyG:
I’m interested in this...you still selling them?
#23 8 months ago
I would like one as well. I've just finished making a playfield overlay and would love to replace the window before applying the overlay.
#24 8 months ago
If anyone out there is crazy and wants a Bad Girls bad enough I have a populated playfield missing A lot of the top side stuff, a lower cabinet wiring harness and transformer. I figure I would at least mention it here since it will all just sit here in storage.
#25 8 months ago
Quoted from 20eyes:
wow,i'm picking up a cabinet in a month or so and would really use this.
pm on the way.
#26 8 months ago
Quoted from pudluther:
it looks like he's out of stock for now.
#27 8 months ago
Only two more reviews and Bad Girls is back in the top 100!
Quoted from jugood20:
#28 8 months ago
Just one more review and it will be listed in the top 100
#29 8 months ago
Done
#30 8 months ago
I still don't see it in the top hundred
#31 8 months ago
It will be added in a couple of days.
Quoted from pinostalgia:
#32 8 months ago
just added my rating
#33 8 months ago
Look, yay
1 month later
#34 7 months ago
My second "bad girls" this will need to be put together...missing parts.
IMG_20201111_122002 (resized).jpgIMG_20201111_122012 (resized).jpgIMG_20201111_122021 (resized).jpgIMG_20201111_122853 (resized).jpgIMG_20201111_122928 (resized).jpgIMG_20201111_122935 (resized).jpgIMG_20201111_122946 (resized).jpg
#35 6 months ago
My two fun pins.
#36 6 months ago
The digital balls in the playfield display window are sometimes all white on my Bad Girls. I assume they’re supposed to always have their colors. It flips back and forth with no rhyme or reason. Any thoughts on what to check to make sure they’re always colored?
#37 6 months ago
That’s by design, the inserts for solids are color and the stripes are clear (you could put color LED’s under the stripes inserts though).
Whether you’re stripes or solids is random, determined at game start
1 month later
#38 5 months ago
Thinking of selling my very nice Bad Girls and wanted to see if there was any interest- located in Vienna , Va
4 months later
#39 41 days ago
Look, yay [quoted image]
Nice She is sitting at the 168th position. Cool
#40 41 days ago
Update; got my sound board fixed up from Clive and with lots of help from woz she has glorious sound again. Still love this game, so much bang for the buck.
I wouldn’t mind grabbing an spare set of drops just in case, anyone know where I could buy?
1 month later
#41 3 days ago
Can someone post a picture of the transformer with fuse info flap? My info flap is missing and I’m having trouble finding info in the schematics pdf on my phone.
