I suppose this is equally tech help and playing advice, but here goes:
How hard to you all find the ramp shots in Bad Cats to be? I find myself frequently hitting the ramps, and finding the ball going most of the way up then rolling back down. I can usually make the ramp shots if the ball has some momentum, but can never make the ramp shots if I've got the ball caught at the base of a flipper. (i.e. I can hit the left ramp, and when the ball returns to the right flipper, I can't get the left ramp again, even with a direct hit.)
This doesn't seem right; shouldn't the ramps be possible to hit when the game's at a normal angle without a ton of extra momentum?
I'm thinking I need to rebuild the flippers on this one. One stuck briefly at one point, and the game probably hasn't had the underside of the playfield serviced in a while. Does rebuilding flippers sound like the most reasonable solution?
Thanks,
Collin
