Make sure you get the one Garret posted - Krylon Triple-thick Crystal Clear Glaze 0500. They make other products that are similar but this is the one to ask for.
Triple-thick is good for sealing backglasses where paint is "lifting" or flaking away. This lifting is usually caused by bulb heat - back in the day, these machines we're left on the whole time the business the open to draw customers. Great idea - not good for the backglass paint though. If your glass is new or has scratches, nicks, gouges, or anything that's not lifting or bubbling DONT USE THIS PRODUCT. Better off to leave it alone.
After 3 coats of this products are sprayed on the glass in a left to right sweeping motion - turning the glass each time for a different direction - you can apply acrylic paints to touch up the spots that are lifting after the Triple-thick is applied. I have about 100 small bottles I bought several years ago. I usually put a coat of white over that to block light. Then, reseal your touch-ups with a smaller amount of Triple-thick. Take your backglass into a hobby store (tell them you're an artist )) You may have to buy a few bottles of each color to mix to get the right backglass color. Some guys use a color chart. This is just my way of doing it - everyone seems to do it a little different.
