I am having a very strange issue with the GI not working on the Green - Green/White wires in the backbox. Here is my troubleshooting:
Wires are plugged in like this on j120 on the board:
Pins 11 10 9 8 7 6 5 4 3 2 1
PW GW P G
- I did test connectivity from the plug to the backbox lighting and there is connectivity on the GW and G wires.
- I tested the voltage coming from the board on pins 10 and 6 and I am getting over 7 volts.
- As soon I plug in the connector to the pins I get no voltage on the wire. The connector is new and the lights on the Purple - Purple/White wires work fine.
I am really not sure what is causing this or how to fix it. I have it plugged in exactly as shown in the manual. Should I reverse it? Like in the diagram below:
G P GW PW
Does anyone have ANY ideas as I am running out of things to troubleshoot as this seems pretty simple. Thanks for the help.
