On a Corvette pin, there a 9 flash lamps in the backbox. The manual only shows 8. All of them, except one, light up when they should. I can't figure out this last one.
The flashers have the black sockets in the picture. The one in question is on the right edge, a little more than half way down. It looks like is has a blu/blk drive wire. The lamp on the bottom edge, 2nd from the right also has blu/blk, but they are separate wires and I do not see anywhere that they connect together.
All the wires connect to the driver board match up with the solenoid/flasher table in the manual. Wires are connected to J124 1-2-3-5, and J125 5-7-8-9.
On the front of the back glass, this mystery flasher would be right at the lower edge of the "Route 66" sign.
Any help would be appreciated!
