Recently picked up a DESW - all was well until...
I removed the screws to the soundboard and let the board float free. This was done in an attempt to eliminate some of the (apparently notorious) speaker hum based on some forum recommendations.
After letting the board float, I fired the game up, and bam, no controlled lighting.
I'd read in the repair wiki about the 8 amp fuse in the backbox often being the culprit, so I checked it with a DMM and it was blown. Got a new one, put it in, turned the game on and pop, blown.
So, I checked the bridge rectifier that's connected to the fuse and sure enough it had a bad leg. Problem solved! Or not.
Ordered a new BR, checked it, installed it, fired the game up with a new fuse in place. Nice glow from the fuse and pop. Retested the bridge and it tested fine, good readings on all legs. Checked the fuse holder, seems fine.
Since I *did* have a shorted BR, and replaced it, but am still seeing the 8 amp fuse pop - any thoughts on where to start looking/testing? It seems odd that this happened immediately after floating the sound board (which has since been re-attached to the backbox), but that could be coincidence I suppose.
