(Topic ID: 234631)
Back To The Future - Full Refub!
By Zenomorp
1 year ago
  • 43 posts
  • 14 Pinsiders participating
  • Latest reply 1 year ago by DropTarget
  • Topic is favorited by 8 Pinsiders
There have been 131 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Ok. Posting the entire project all at once here so bear with me. Here's the scoop. Found this at a local distributor's warehouse and it had been sitting with no glass for 10+ years. Boxes and other heavy items had been sitting on the playfield for most of that time which bend/warped all the plastics, the ramp, anything that was bendable, and needless to say, it was filthy. The MPU, power supply, and display had been robbed for some other game. Fortunately, those were the only missing parts. The backglass was in terrible shape as well. Someone decided to use acetone or some other thinner to try and clean it and ended up removing all of the white 'coating/paint' from the back. the cabinet was solid, no damage, but as you can see from the pics below, was in TERRIBLE condition cosmetically. I really had my work cut out for me but I was determined to bring this machine back to factory glory.
Started with a full teardown to determine what parts I would need and other necessities. Got all the missing boards ordered, rubbers, new posts, LED kit, etc. All the normal stuff as well as new glass and new lockdown bar since those were also missing. After tearing down the playfield, I realized it would require touch up in numerous places. I'm no Picasso, but I was able to get that done to my satisfaction. Not too many wear spots, but there were a few. Nothing too major. After getting the playfield fully torn down, cleaned, and assessed, I moved on to the cabinet. Now here's where the real work went into this.
Currently, there are a few sources for repro artwork for BTTF. However, it's all completely inaccurate. Wrong background color (too light of blue), wrong image boarder color (gray vs. turquoise), no shading, no half tones, incorrect watch image, etc. Because of this, I took it upon myself to scan a previous BTTF I restored with a hand scanner and painstakingly scanned the entire cabinet one foot at a time, stitched up and cleaned up all the images in Photoshop and reproduced the most accurate artwork possible. You can see from the pics how good it turned out. I'm willing to share the artwork if anyone wants it. Also, I removed one of the planks on the back of the cabinet, took it to Lowe's and they were able to color match the cabinet EXACTLY. I posted a picture of the paint code as well in case anyone wants that too.
While waiting for the artwork to get printed, all the parts I had ordered arrived including a new playfield protector. I deep cleaned, touched up, installed the protector, and reassembled the playfield. I was able to flatten out and reshape all the bent/warped plastics using a heat gun. It worked great. Saved me from having to get a whole new plastics kit. Got all the missing boards and display installed, hooked everything up, went over everything with a fine-toothed comb, and powered up the machine. To my amazement, everything appeared to be working except the solenoid that launches the ball into the shooter lane and the VUK solenoid were locked on. Quickly turned off the machine and found the diode on both coils shorted. Replaced the diodes but they were still locked on. Turns out the shorted diodes also shorted out the transistors on the brand new MPU for those coils. Fortunately I had some on hand, changed them out, and that fixed the issue. Tested every coil and every switch. The machines was 99.9% operational. The remaining 00.1% was a bad audio amp for the left speaker. The right speaker and cabinet speaker work fine but the left speaker just hums. The amp is bad. I'm going to replace it later once I get a change since it's not necessary at the moment.
So with the the machine running with no issues, I removed the playfield and began work on prepping the cabinet and backbox for the new artwork. Fully stripped everything down, cleaned, sanded, painted all exposed areas where there would be no artwork, sanded again, and applied all the artwork. It all turned out absolutely perfect. You can see from the pics and I think you'd be hard pressed to fine someone to disagree. Reinstalled the backbox on the cabinet, reinstalled all removed items, reinstalled the playfield, hooked everything back up, and it's still without issue. Running perfectly and ready to go! Super proud of this project. This is now one of the nicest BTTFs you'll see anywhere around. I'm posting all the new parts below along with a...(ahem)...crap-ton of gratuitous pictures.
Thanks for looking and any comments, good or bad, are appreciated.
-Mike
-) Full flipper rebuild kit
-) New flipper coils
-) New MPU
-) New power supply
-) New display
-) New rubber kit
-) New playfield posts (some were missing/robbed for another machine)
-) New artwork
-) New playfield protector
-) New drop targets
-) New drop target decals
-) New drop target springs
-) New springs for a few coils (they were missing)
-) New plungers for a few coils
-) Custom holographic 'instruction' card
-) Full LED kit
-) New legs
-) (Probably a few other things I'm forgetting)
IMG_3183 (resized).JPGIMG_3184 (resized).JPGIMG_3185 (resized).JPGIMG_3186 (resized).JPGIMG_3187 (resized).JPGIMG_3188 (resized).JPGIMG_3189 (resized).JPGIMG_3193 (resized).JPGIMG_3195 (resized).JPGIMG_3196 (resized).JPGIMG_3197 (resized).JPGIMG_3198 (resized).JPGIMG_3199 (resized).JPGIMG_3200 (resized).JPGIMG_3201 (resized).JPG
#2 1 year ago
IMG_3203 (resized).JPGIMG_3204 (resized).JPGIMG_3205 (resized).JPGIMG_3206 (resized).JPGIMG_3207 (resized).JPGIMG_3208 (resized).JPGIMG_3210 (resized).JPGIMG_3211 (resized).JPGIMG_3221 (resized).JPGIMG_3222 (resized).JPGIMG_3225 (resized).JPGIMG_3226 (resized).JPGIMG_3227 (resized).JPGIMG_3230 (resized).JPGIMG_3231 (resized).JPGIMG_3232 (resized).JPGIMG_3233 (resized).JPGIMG_3234 (resized).JPG
#3 1 year ago
IMG_3237 (resized).JPGIMG_3238 (resized).JPGIMG_3239 (resized).JPGIMG_3241 (resized).JPGIMG_3243 (resized).JPGIMG_3245 (resized).JPGIMG_3310 (resized).JPGIMG_3311 (resized).JPGIMG_3337 (resized).JPGIMG_3338 (resized).JPGIMG_3340 (resized).JPGIMG_3353 (resized).JPGIMG_3341 (resized).JPGIMG_3349 (resized).JPGIMG_3342 (resized).JPGIMG_3347 (resized).JPGIMG_3344 (resized).JPGIMG_3348 (resized).JPG
#4 1 year ago
IMG_3234 (resized).JPGIMG_3236 (resized).JPGIMG_3579 (resized).JPGIMG_3588 (resized).JPGIMG_3590 (resized).JPGIMG_3582 (resized).JPGIMG_3584 (resized).JPGIMG_3594 (resized).JPGIMG_3586 (resized).JPGIMG_3592 (resized).JPGIMG_3593 (resized).JPGIMG_3596 (resized).JPGIMG_3597 (resized).JPGIMG_3603 (resized).JPG
#5 1 year ago
IMG_3606 (resized).JPGIMG_3605 (resized).JPGIMG_3621 (resized).JPGIMG_3622 (resized).JPGIMG_3623 (resized).JPGIMG_3628 (resized).JPGIMG_3645 (resized).JPGIMG_3648 (resized).JPGIMG_3624 (resized).JPGIMG_3625 (resized).JPGIMG_3626 (resized).JPGIMG_3627 (resized).JPGIMG_3641 (resized).JPGIMG_3643 (resized).JPGIMG_3651 (resized).JPGIMG_3652 (resized).JPGIMG_3653 (resized).JPGIMG_3654 (resized).JPGIMG_3655 (resized).JPGIMG_3658 (resized).JPGIMG_3659 (resized).JPGIMG_3661 (resized).JPGIMG_3660 (resized).JPG
#6 1 year ago
Welcome to the fun! Looks beautiful so far.
#7 1 year ago
IMG_3589 (resized).JPGIMG_3688 (resized).JPGIMG_3691 (resized).JPGIMG_3693 (resized).JPGIMG_3694 (resized).JPGIMG_3695 (resized).JPGIMG_3699 (resized).JPGIMG_3704 (resized).JPGIMG_3711 (resized).JPGIMG_3714 (resized).JPGIMG_3715 (resized).JPGIMG_3724 (resized).JPGIMG_3728 (resized).JPGIMG_3729 (resized).JPGIMG_3730 (resized).JPGIMG_3732 (resized).JPGIMG_3733 (resized).JPGIMG_3736 (resized).JPGIMG_3737 (resized).JPGIMG_3739 (resized).JPGIMG_3743 (resized).JPGIMG_3745 (resized).JPGIMG_3747 (resized).JPGIMG_3753 (resized).JPGIMG_3749 (resized).JPGIMG_E3604 (resized).JPGIMG_3754 (resized).JPG
#8 1 year ago
Looks great.
That was one filthy BTTF. Great job saving one that would have been trashed at some point. You should be proud.
And you've got Michael J. Fox represented!
How did you print the art? If you care to share, I wouldn't mind the files. My BTTF is in 1/2 way descent shape, but you never know.
#9 1 year ago
Quoted from DropTarget:
Looks great.
Thanks. I am. I had a friend over at XL Arcade print everything for me. I'll get them uploaded when I can and share them. You can also order a set printed and laminated straight from XL Arcade if you'd rather do that.
#11 1 year ago
Quoted from Zenomorp:
it looks like you've got those shots down pat!
#12 1 year ago
Thanks for posting the paint codes. Also interested in buying/making a set of decals.
Great work saving one from the trash!
#13 1 year ago
I never see these pins! This is where they are all at!
#14 1 year ago
Really nice work bringing a wreck back to life.
#15 1 year ago
Lotta work bringing these back from the brink! Very nicely done!
#16 1 year ago
Thanks all. NOS backglass arrived today courtesy of Mayfair Amusement. The project is now complete.
6CC2C797-0194-4A0C-8626-F4766C891190 (resized).jpegA44D6156-2657-4C29-816C-5956DCBEFD87 (resized).jpeg41923B84-A7F1-48DE-BC3D-52A7F08AB6F1 (resized).jpeg5E354255-DD2C-4B2B-B1AA-307CE2FC41D8 (resized).jpeg2127C438-2482-4FD2-9ED5-B99222C1CAD6 (resized).jpegCDB1898C-1835-4AA5-82EC-3A9E86D37522 (resized).jpeg502D86EB-274C-42CA-BEE3-76A134B1816C (resized).jpeg7A2AF008-AB47-47E0-86AB-8F78E4A2C866 (resized).jpegC4343007-0DCB-414D-82DA-0F6DCD87749D (resized).jpeg86A55065-2455-46A1-80FF-4E915907E0DF (resized).jpegBE407C01-C83C-4E16-9C58-19E0369BC48D (resized).jpeg
#17 1 year ago
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
WOW! How did you track that one done? I figured that was unobtanium!!
#18 1 year ago
Quoted from ypurchn:
Mayfair Amusements actually had two of them!
#19 1 year ago
All set up in the row and ready to go!
9CA1CB59-9B12-4DE5-9A91-8340AB2AA32F (resized).jpegB8FECED0-06D9-48C6-B691-A365345F7DDE (resized).jpegBF01AF2F-AF0F-4AC6-A282-9FC2F939883B (resized).jpegEF6881B7-3971-4057-BF77-FDC3D7E2F853 (resized).jpegF58F9891-8DCD-4C32-A91E-A2B69D47C4E9 (resized).jpeg
#20 1 year ago
Sweeeeeeet
#21 1 year ago
Incredible setup. I love the screens above the pins.
What pin is inbetween southpark and the addams family?
#22 1 year ago
Quoted from Daditude:
Thanks. Road Show.
#23 1 year ago
Here's the link to the artwork I said I'd share if anyone wants it. If you use it, give me a shout out!...
http://www.mediafire.com/file/g13mwxp6t8gb6q9/BTTF+Art.zip
#24 1 year ago
Awesome!
Curious, how does the Marty pic work in the instruction card spot? And how do I get one?
#25 1 year ago
Thank you.
Looks great. Did you paint the blue and then create decals for the actual art?
#26 1 year ago
forgive me if this has been addressed elsewhere but did they not have the rights to Michael J. Fox's image when they made this game?
#27 1 year ago
Quoted from lint:
Correct
#28 1 year ago
Thank you.
I scanned a cabinet and reworked all the scans in Photoshop.
#29 1 year ago
Quoted from Irishbastard:
Awesome!
It’s a hologram that comes in this book...
amazon.com link »
#30 1 year ago
I figured that (nice job btw). I was wondering how it was applied to your cabinet ie: all painted, printed on vinyl, a combination, etc.
#31 1 year ago
Oh, sorry. It was printed vinyl.
#32 1 year ago
Thanks. I was just wondering because you posted the paint color. That confused me.
#33 1 year ago
Your playfield display setup is excellent. Can you switch feeds to other screens, or is each one self-contained? I'm toying with ideas for an IP camera setup that could be switched in software for projecting and streaming, in addition to a local display above the pin.
#34 1 year ago
well done on the repair sir
#35 1 year ago
looks great! any chance you know the colors used on the inlane, where the ramp drops the ball down?
Nice rescue!
Thanks,
Chad
#36 1 year ago
it's a wonder that one made it without getting busted with them shipping it like that! Ridiculous!!
#37 1 year ago
Quoted from Yetimon:
Thanks. Each one is dedicated to each machine. Just a camera over the PF feeding a monitor.
#38 1 year ago
Quoted from crussell:
Nice rescue!
Thanks,
Chad
Testors Model Enamel Paints.
Turquoise, Gloss Black, and Gloss Red.
#39 1 year ago
Quoted from jake35:
It was in a much bigger box packed very well, I just didn’t show that. It definitely wasn’t shipped like what you see in the pictures. Sorry.
#40 1 year ago
Yikes! You should never use Testors' model paints, not even on models. They're just complete crap and will dry soft, plus if you clearcoat over them they'll run and ruin your playfield.
#41 1 year ago
Quoted from jibmums:
Never had that issue and not really worried about that since it’s all under the protector, but I don’t doubt you.
5 months later
#42 1 year ago
Do you know of a similar silver paint to use on the cabinet for the DeLorean? It seems metallic and reflective. I know that you used decals, but you seem to know a bit about paints.
Fantastic restoration job!
Adam.
#43 1 year ago
Check Montana spray paints.
$ 54.99
Gweem's Mods
Québec, QC
Davie, FL
$ 21.00
Professor Pinball
$ 48.00
$ 80.00
Loop Combo Pinball
