I'm trying to Bring a Baby Pacman back to life. I just managed to repair the MPU, thanks to various suggestions here on the forums.
So, the vidiot board boots, the MPU boots, and there is a light show on the playfield. On the monitor, I can display a bar test and display a communication test. However, the two columns of numbers do not match up. Do these numbers actually provide any useful information?
I looked at the W-1282 cabinet diagram and did continuity tests between the vidiot's J1 connector and to wherever those connections ended up (J1 and J2 on the MPU). All that was successful--there were no dead or disconnected wires.
Then, I tested pin connectivity between the connector and the pins on the boards (vJ1, A4J1, and A4J2). All those connectors made contact with their pins.
So--is there something I should try or test for next?
