(Topic ID: 315224)
baby pacman trembling flipper
By quantumjosh
1 year ago
#1 1 year ago
just finishing fixing the light driver board on baby pacman and now something new.. the left flipper is trembling when held like flipping repeatedly and generally causing the playfield to brighten as well. is replacing the flipper coil going to be the likely solution here or would this be caused by something else? thanks!!
#2 1 year ago
Could be the coil, but check that your EOS switch and cabinet flipper switch are gapped properly and not pitted.
#3 1 year ago
Just FYI, that's sometimes referred to as a chattering flipper. You may see more search results using that term.
#4 1 year ago
A chattering flipper is caused by an open holding coil. Carefully examine the coil and see if one of the smaller coil wires has broken off the lug. If that's the case you can sometimes unwind the wire a small amount and reattach it. Otherwise you'll need to replace the coil.
#5 1 year ago
big al you got it right wire to the flipper coil had come off
$ 100.00
The Flipper Room
2,250 (Firm)
Reno, NV
$ 199.95
$ 9.95
$ 45.95
This page was printed from https://pinside.com/pinball/forum/topic/baby-pacman-trembling-flipper and we tried optimising it for printing. Some page elements may have been deliberately hidden.
