After an almost 2 year search, I finally brought home a Baby Pac-Man yesterday. Got a few small things to work on, like a wonky left flipper. Sometimes it flips at 100%, other times it flips at 50%. It also needs to be "calibrated" as right now due to the angle of the flipper you can't hit most of the drop targets. Also, my left drop target only drops down about 80%, leaving a portion of it sticking up and blocking the ball. After a couple of extra hits it usually falls down all the way. I also have a few lights that I need to replace (game is already switched over to LEDs). Lastly my sound isn't right. Even with the volume knob turned all the way up you can barely hear the game. I haven't looked into any of these issues just yet, however I did have one thing that has me stumped. How in the hell do you reset the game defaults, or at least reset the Hi Scores? I went through the manual, and I saw the setting for manually lowering/raising the scores at 10K intervals, but that will take forever. Is this the correct way to reset the scores?
"With the game off set all the "Game Select Dipswitch" switches to 1 (up) except for Dip #1 which should be on 0 (down). Then turn the game game on. Wait a few seconds (maybe a minute). Then set the Game Select Dipswitch back to the Baby Pacman settings. The settings are... 00110100 or dduududd"
