Quoted from gameover1173:Your cpu is working good too?
The sockets on the vidiot board are good?
No acid on either board?
Just giving ideas
Quoted from ForceFlow:For all the socketed chips, are all the legs clean and untarnished? Any damage around the sockets from prying up chips improperly?
Most of the sockets have been replaced. I did this to go from dead to 10 flashes. I admit one of the ROM sockets has not been replaced, but I would expect that it wouldn't go through the complete flash sequence. The legs on the ICs have been cleaned.
MPU is a new Alltek. MPU connectors and pins have been replaced
I did learn something about the pervasiveness of battery damage. Visually, the ROM socket pins looked fine, but replacing them fixed the original boot issues.
Maybe a bad video ram chip that isn't being picked up by the boot test?
I don't think the video amplifiers can fail this way, but maybe a problem with u17 or u18?
Maybe garbage data is being fed in to the video processor somehow?
I really think you are on to something here. I really believe the issue is in the Video processing section. I was wondering if anyone has seen a failed video processing crystal that might cause this? But then again, the chances of a failed crystal are pretty minuscule. But that's me! I seen to get all the odd-ball problems that occur once in a lifetime for everyone else.
So, Video RAM first. Will report my findings.
