Hello everyone,
I've just joined this forum after weeks of reading different post on here about baby PAC man isssues. This is the first arcade I've restored. When I got it nothing would power up at all. So I've worked through several issues over the last few weeks. Thanks to all the great information here.
I am now at the point where I have seven flashes on my vidiot start up light ( occasionally I will only get one but I can retry the start and get seven again ) ,and one flicker with 6 flashes on my mpu . And all the lights and relays test seem to be working as designed.
Now ,according to the manual the eighth flash that I can't get is supposed to be a test of the PIA at U7 (MC6821P) . Since the mpu is booting fine and it has two PIAs the same part numbers I swapped with one of those With no change in light sequences on either board. Then I tested the socket at u7 with the pia plugged in I had continuity from each pia pin to the back side of board on all forty pins. I am at a loss as to what else to try.
Things I have repaired.
-removed/relocated battery pack
-repaired acid damage (two bad traces)on mpu
-cleaned and tested pins on mpu
-replaced 5 bad sockets on vidiot
-cleaned and tested rest of sockets
-cleaned and tested pins on vidiot
-replaced three bad pots
-tested(looked) for bad or damaged traces on vidiot
Machine statis on start up.
Powers up speaker buzz on start then quiet.sound test does nothing.
Screen lights up different shades of blue /green /red depending on how I move pots on vidiot. Screen test does nothing .
Play field lights up in attract mode .
Light test works
Relay solenoid test works
I did notice there appears to be a socket added to the harness at the cabinet hinge.?? Seems to be a joint all the wires twisted and tapped no solder. I would like to remove it and clean it up. But I'm not sure if it's needed?? Any help would be appreciated. Thank you.
