http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Second_flash
Voltages all within tolerance at test points on the MPU.
I get the flicker then two flashes. Replaced the socket and the 5101 - no change. Also tested the continuity points suggested in the pinwiki link - all check out good.
Swapped out known good ICs for all socketed chips (except the game ROMs) as well.
All I haven't done yet is replace the 4011 at U19 as it's suggested that could be a long shot problem.
The Vidiot appears to be working in that I can get the video test to run at least.
Lastly, FWIW, Eldorado games had repaired this back in 94 and verified it's a baby pac MPU (sticker and their tag on the board).
Suggestions?
