I don't know yet, I am still deep in the weeds getting this game restored, before powering everything up for the first time. They guy I bought it from had got it from a lot of 50+ games he picked up in bulk, so this unit was in unknown condition for everything, other than what I could see. I at least knew that pretty much every part was present, if not in the best shape. I vowed to make sure I checked out and laid hands on every part of this thing before even plugging it in.
So far I have already :
*Replaced T-molding on cabinet (T-molding was missing, but when I bought it, it came with a replacement set that had blue for the sides and pink for the top, which looks pretty decent for a color scheme)
*Replaced damaged power cable
*Replaced missing and improper amp fuses
*Checked out the power supply, and changed out the fuse holders on the power board. (I did plug in the power at that point to confirm I had correct voltages coming from power supply and power board)
*Flipper rebuild kit, including new coils for flippers (one of the coils had a sleeve stuck that I couldn't get out)
*New Flipper bats
*Replace a broken leaf switch on one of the side bumpers
*Re-attached the wiring going to the speakers that had been cut at some point
*Replaced missing hold-downs for wiring harness under playfield
*Changed out the transistors for all the lights, and the capacitor on the driver combo board.
*Repaired a broken trace and a couple of bad solder pads on driver board
*Re-flowed connectors on combo driver board
*Scraped off an old failed clearcoat/mylar (not sure what it was) that was over the overlay, and was flaking off.
*Re-pinned all the connectors
*Swapped out all the lamp sockets for LEDs and also new sockets for GI
*New locks
*Repainted the black on the inside side panels, as it was pretty scratched up down to wood in a places.
*Re-attached some flaking on the backglass and marquee with triple-thick clearcoat
*Added rubber U-channel to the edges of the playfield glass
*Removed all the playfield parts, ran metal parts through evapo-rust, and then rock-tumbled small parts in crushed walnut shells to polish
*Cleaned/lubricated the coin eject buttons, as they were stuck
*Replaced the grounding strap going to coin door
*Cleaned and adjusted the saucer kickers
*Checked and replaced missing / bad diodes on lamp sockets (but hose have since been ripped out to put in the LED kit, lol)
*Checked and reflowed/reconnected wiring going to all the coils/switches (most of them were pretty gnarly with several broken wire repairs that I removed and re-attached wire cleanly)
Still left to complete:
*Add in proper label-maker labels, instead of just sharpie marks for harness connectors before re-installing it.
*Install new alltek MPU
*Re-cap the monitor
*Re-flow connectors on Vidiot board
*Restore / clean up the drop target assembly, including new drop targets, and replacing a missing rod that goes through
*Replace springs on memory coils for drop target (one of them was weak)
*Adjust the leaf switches for drop targets, (and any others on the playfield)
*Run the board mounting brackets through the evapo-rust bath to remove corrosion from old battery leakage.
*Clean up and wipe down back door under the mounting brackets before re-installing brackets.
*3 of the wire ball guides have broken wires at the base, need to fabricate replacements from stainless welding wire.
*Re-install playfield parts, including new rubbers, plastic posts, and new silkscreened plastics.
Adjust and lock down position of flipper bats (they are only currently on finger-tight when I did the rebuild, as to not make a heavy indent on the new ones before I had the playfield back together to set the right angle)
*One of the screws holding on the marquee bracket is broken off in the wood, I need to drill out the old screw, plug it with wood, and then put in new screw.
*Install new leg levelers
*Install new pinballs
At that point I'll plug in and test it out.....
Not necessary to get it working, but I also have some LED light strips to add in to light up the backglass around the monitor, and also light up the marquee, instead of using the old fluorescent light.
I also have some black light strips I am going to try out in the playfield area, as I bought the radiant rings rubbers for the playfield, which should light up blue if under UV light. (If anyone knows where to get a yellow pinball that can glow under UV, let me know)
I also want to get some of the spinner decals, and probably a new control panel overlay, but those can wait, don't need those to play game.
After all that then I can power this thing up and see if I need anything else, as I am Still unsure if the vidiot or monitor will need more work
I have parts ready for replacement if needed on :
*volume potentiometer on coin door if needed
*5 adjustment pots on vidiot
*Flipper button leaf switches
Well, I just made this bullet point list, as much for my benefit as anyone else's too, as I had not typed it all out yet... I guess I have most of the things done, and am getting pretty close.
