Got me a under the cabinet Flasher Kit from CoinTaker yesterday. Took me about 1 hr and 10 min's to install.. I could do the 2nd 1 now in half the time.. The Flasher strip's come in 3 Piece's with Link up cable's for each. They are pre-sized for the under-side ( Entire Cabinet length )... Poke a hole thru a vent in the Left back corner and feed the wire inside. Main wire has 4-wire's , The Black is for The Power or ( Hot ) .Red , Blue and green are the other wire's.. Tap into a Flasher of yr choice.. The Black is Only used Once.. The Remaining color wires are attached to the Flasher side of the socket.. Was Fairly simple to install and What a Light-show it Produce's.. This is my Sample Video , I will film another 2-nite w/ the p/f up show-n how the wire's are installed and a view from under the cab.. This Flashed mod Can be Used on Any Pin !!!!!!
Remember ,, Sample Video-
CoinTaker u- p/f Flasher link http://shop.cointaker.com/product.sc?productId=1037&categoryId=8
