(Topic ID: 109276)
Aztec machine lighting extra lights
By n1teowl
5 years ago
  • 10 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by Pin-it
#1 5 years ago
This is probably very specific to an Aztec machine, but here goes. The targets A-Z-T-E-C light the corresponding lights in the upper right lane. With one of the targets, 'T', both the T and the Z light up in the upper right lane. The point values it assigns, however, act as if the Z wasn't lit. When I light the Z up after the fact, then the points for the Z are applied. It doesn't really affect game play, but it's hard to tell if the Z is really lit or not. Each switch has a wire coming in and out to provide power, and two other wires going in of different colors (one on the end of the switch and one on the side). Not sure how to proceed at this point, it's just kind of odd behavior and nothing looks obviously wrong. Any ideas are appreciated. Thanks!
#2 5 years ago
Look at the wiring at the T and Z lights underneath the playfield. I'd check for an incorrect connection between Z and T that's causing both to turn on when you make the T target.
Don O
#3 5 years ago
Thanks Dono, I'll check those connections out and see if anything looks strange. It might be hard to know though, as once the wires come off the switches they end up in a giant bundle of wires.
#4 5 years ago
I would think the cross connection issue would be on the wires underneath the lights prior to the bundle; very seldom are you going to have shorts inside the wire bundles themselves, unless fire has been in the game's past.
Don
#5 5 years ago
Sounds like the Z re. m&b [make and break] is the issue.
Post edited by Pin-it: Ignore this posting
#6 5 years ago
Awesome - thanks so much. I will check this out this weekend and see what I can figure out.
#7 5 years ago
Alright, haven't fixed it yet, but have been making some progress. I identified the swtich that you circled above Pin-it. Nothing seemed obviously wrong and I traced the wires back to figure out which lights they were lighting, etc. It didn't seem to make any sense to me for the yellow-orange wire to be there. When I blocked the make and break switch with a business card, the extra 'Z' light no longer turned on. I thought I should see what would happen when I disconnected that wire so I desoldered it. I now noticed that the two double bonus lights were now not turning on. They are supposed to light up when either "Z' or "T" targets are hit. I resoldered the wire and saw that things were back to the way they were (extra "Z" light coming on when "T" was hit). I did notice something else strange, though, something that I might have missed before. When you hit the "Z" target the double bonus lights come on as they should. When the "T" target is hit, however, those lights don't come on. It might have always been this way and I didn't notice. It almost seems like the wires are not attached correctly. It's like the "T" target triggers the wrong light - "Z" instead of the two double bonus lights. Might these be swtiched somehow? If so, what should I disconnect and where should I reconnect it? The mystery deepens...
#8 5 years ago
I seem to have mis-understood your issue,going back to your first post you are saying that → one of the targets, 'T', both the T and the Z light up in the upper right lane.
If you follow your 'T' relay make and break[yellow wire -yellow orange]were to back feed then the T & Z targets would both light,not the 'Z' m&b as i pointed out in the previous post.
I would check the 'T' relay m&b [probably barely touching]would cause what your getting.
#9 5 years ago
It's really strange, I investigated that relay and see nothing wrong at all. All of the switches are working properly, it almost seems like something was miswired from the beginning. Not sure what to try next but am open to suggestions. Thanks again for your help so far.
#10 5 years ago
Quoted from n1teowl:
Patience and a continuity tester/Dmm would be the next option if you dont see anything.
$ 4.49
$ 6.00
German-Pinball-Modular
$ 24.00
Pinball Mod Co.
Pinfarmer Mods
$ 29.95
Pinball Photos
$ 69.99
$ 54.99
$ 63.00
$ 48.00
Apparel - Unisex
Project Pinball Charity
$ 4.49
$ 11.95
$ 68.50
$ 99.99
$ 48.00
$ 5,799.00
Nitro Pinball Shop
$ 79.95
$ 11.95
Pinball Wheezer
