(Topic ID: 300513)
Aztec chime stays energized
By NickyVanHalen
2 years ago
#1 2 years ago
Aztec 1,000 point chime works 1st 8-12 times it's activated then stays energized and won't work again till I turn game off. Then repeats that scenario. I can see the 1,000 pt relay properly closing and opening when the chime works and after its locked on. Any suggestions?
#2 2 years ago
Check the black rubber base where the coil plunger drops, it may be sticking.
Clean the plunger shaft with alcohol.
Check for burnt coil
#3 2 years ago
Could it be the chime plunger is mushroomed and sticking or the inside of the sleeve is gummed up?
#4 2 years ago
I had one where the black rubber base liquified and got into the sleeve.
#5 2 years ago
It's not sticking the coil is staying energized, as soon as I cut power it drops. Don't know how it's staying energized when the 1,000 pt relay leaf switch that activates it is open?
#6 2 years ago
Are you sure none of the 10, 100, 1000, or 10,000 Point relay are locked on when this happens?
#7 2 years ago
Thanks Howard R the 10,000 pt relay is sticking closed and does this on all players. What should be opening that back up
#8 2 years ago
Check the bottom left and right outside rollovers for a closed switch.
#9 2 years ago
I GOT IT!!!! 10,000 pt relay leaf that activates score drum wasn't making enough contact, now it's activating and then opens back up all is good. Thanks for all your time and help
Beehive Pinball Co.
Ashburn, VA
This page was printed from https://pinside.com/pinball/forum/topic/aztec-chime-stays-energized and we tried optimising it for printing. Some page elements may have been deliberately hidden.
