(Topic ID: 269259)
Aztec 100 and 1000 point score same time
By Ott
12 days ago
  • 8 posts
  • 2 Pinsiders participating
  • Latest reply 6 days ago by currieddog
#1 12 days ago
this does it on all 4 players, I suspect the bumpers, change relay, match unit issue or could it be all score units EOS since it does it on all 4 players?
#2 12 days ago
Looks like it could be D and/or E on this relay. Clean and make sure they're making solid and correct contact.
#3 10 days ago
Not the change relay. New info if the score is on the playfield they both score but if i manually operate the 100 or 1,000 point relay only it scores.
#4 10 days ago
I would check the Player Unit for misadjustment or a short, etc. PU is on p.18 & 19: https://www.ipdb.org/files/119/Williams_1976_Aztec_Instruction_Manual.pdf
#5 7 days ago
checked the player unit for maladjustment. Adjusted up and down with the stop bolt on the relay checked for any shorts did not fix problem. Jumped Jones Plug individually one at a time and would score correct correctly. If operated individually the 100 score also would lock up at 9 on all 4 players and once when jones plug in 100 and 1,000 point score together.
#6 7 days ago
Quoted from Ott:
Can you clarify that last part a bit? Thanks
#7 7 days ago
When any of the 100 point score reel reaches 9 it locks up the 100 and 1,000 point score reel. Any 10 point will unlock. This is on all 4 players. With both score reels going at the same time i got the reels out of sequence and determined the 100 points are doing this.
#8 6 days ago
Quoted from Ott:
Since that worked I would expand the jumpering so you can see exactly at which point things change from correct scoring to the lock up.
$ 12.00
$ 3.00
Various Other Swag
$ 78.00
£ 49.00
PinballToys
$ 249.00
Tilttopper
$ 229.00
Tilttopper
$ 69.99
$ 7,500.00
$ 159.99
$ 16.95
$ 54.99
$ 218.00
$ 86.95
$ 54.99
$ 9.00
$ 5,699.00
Classic Game Rooms
