Restoring a 1977 Gottleib bronco. Need the sequence on the ax and bx relays. All open. All closed or what mix. Any help or link to references would be great.
Hi Jonathan, Welcome to pinside.
Quoted from Croppie1Kenobi:Any help or link to references would be great
Gottliebs of that era show the complete reset sequence on a page in the manual.
Quoted from HowardR:Hi Jonathan, Welcome to pinside.
Thank you! Manual ordered. So thankful for this community.
Quoted from currieddog:To mull over til you get the manual:
i swear i'm not completely stupid but what does " 1a, 2c..." mean on the contacts list?
Quoted from Croppie1Kenobi:i swear i'm not completely stupid but what does " 1a, 2c..." mean on the contacts list?
One normally open switch and two make/break switches. A means a normally open switch, B means normally closed, and C means make/break. This relay has 1 normally open, 3 normally closed, and 3 make/break.
As Chad noted, they can be fiddly. They are short throw and quite often people have monkeyed with them and bent the long blades or gotten them in the wrong slot.
Quoted from EMsInKC:One normally open switch and two make/break switches. A means a normally open switch, B means normally closed, and C means make/break. This relay has 1 normally open, 3 normally closed, and 3 make/break.
thank you all so much!
Quoted from EMsInKC:As Chad noted, they can be fiddly.
A bit of reading on them: http://www.pinrepair.com/em/index3.htm#reset
Quoted from chad:And make sure you get tbe AX relay just right. These can be very picky!!
I'd go so far as to say they can be very pricky as well.
This page was printed from https://pinside.com/pinball/forum/topic/ax-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
