Quoted from northerndude:Hey all, found a little nugget I had to tweak fix, here’s what I did, hope this doesn’t happen to you, but might save some troubleshooting for you in case it does.
I had a coil firing intermittent but quick and repeatedly. I couldnt see it to see what could have been hitting, it was only the sound and nothing was moving g. so I lifted the PF and had to check while game was on, what it was was the leaf switch for the scoop to register a ball inside wasn’t getting enough travel upwards to show the switch was open. It was pressing in the bottom of the scoop metal and was staying closed. You’ll see right at the spot where my yellow stick is pointing. I had to bend the switch down a bit so it could travel up and release. Just an FYI for anyone that may stumble upon this.
This pic is aiming back up the scoop from below it.
While checking that on the scoop you may want to make sure the wires for that coil are out of the way of that metal plate that pushes the car up. The solder got knocked loose on mine and it stopped working. It looked like the wire and plate may have been in the way of each other so I tied the wire up and out of the way. Going to have to re-solder, first time I've ever done it so any safety tips? I'm assuming all I have to do is put it back in place and melt it back in there. I have a picture I can post if anybody is curious.
