(Topic ID: 257850)
Official Rick and Morty Club - You are not like other carbon based life forms.
By TheNoTrashCougar
  • 19,647 posts
  • 708 Pinsiders participating
  • Latest reply 3 hours ago by Jigz
  • Topic is favorited by 334 Pinsiders
105 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 19,647 posts in this topic. You are on page 80 of 393.
#3951 2 years ago
Finally set up, I have a feeling stranger things will get a few less plays now
#3952 2 years ago
Just received the options email...#139.
Anyone know if butter cab requires additional build time?
#3953 2 years ago
Quoted from Yelobird:
What are you talking about #zaphX? All games are complete though they opted to Skip shipping to Texas. Sorry. lol
I cannot blame them for this.
#3954 2 years ago
Got my final invoice and made payment today on #123 for those keeping track of progress
#3955 2 years ago
Quoted from xfassa:
I believe earlier in thread spooky said it would not take longer.
#3956 2 years ago
another quick question. At first the game played great, but after about 20 games or so, I started noticing intermittent issues with the right flipper(s). Most often with the lower. But occasionally with the upper as well. Some times they will not respond to button presses. Or if you will be holding the flipper it will drop and hit again. Or sometimes only half hit. It has gotten to where it happens on nearly every ball. If you hit the button a few times it goes back to normal. I checked the leaf switched to see if there was any dust or anything blocking the connection, but after that I figured I should consult the experts.
#3957 2 years ago
Quoted from brerspidur:
Second paragraph...
https://pinside.com/pinball/forum/topic/aw-jeez-official-rick-and-morty-club/page/76#post-5706474
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#3958 2 years ago
15 hours since last post? Unacceptable!
#3959 2 years ago
BSE 640 checking in. I was disappointed that I could not pull the trigger back in December, but am happy that I was able to snag a spot recently. Sure it'll be probably next summer before I get mine, but sounds like I'll be in good company waiting with everyone else near the end of the run. Happy to see that Spooky is taking feedback to heart and makes me feel good knowing that they keep striving to make each and every machine they build better than the one beforehand. My TNA has been rock solid ever since it came home from the factory and I am eager to see how Rick & Morty improves on that. Keep up the great work!
#3960 2 years ago
One day I hope to pick one of these up as it looks like an awesome game with phenomenal theme integration, coding and rules.
I really hope issues like dodgy flippers and shooter lane mech gets improved though.
Game is shaping up to be a classic, that is for sure.
#3961 2 years ago
I've been hard on the shooter lane design, mine has plagued me since I got it. I've spent hours tweaking it but today I think I finally found the issue. The left hand wooden side rail, between the shooter lane and the right outlane was positioned too far to the right, so the ball could just about touch it as it was shot up the shooter lane. I repositioned it today just a mm or 2 to the left and now have a consistent ball speed. I still think its a bit of a weak design, particularly the last few inches of the wire form but at least now with a consistent ball speed I can get the ball on the playfield properly.
#3962 2 years ago
Quoted from xfassa:
Luke recently said butter cabs are in stock and do not cause delay. My #81 was butter cab.
#3963 2 years ago
Yesterday when I spoke to spooky, I was told a butter cabinet will not hold up my #134 build.
15
#3964 2 years ago
Some early impressions on the latest builds -- I received mine Tuesday:
Build quality is really nice. The decals are the by far the nicest I've seen from any manufacturer.
I have had no issues with the spinner shot not hitting cleanly. They seem to have adjusted the angle/position of the rail, drilling new spots for the screws, rather than just removing the screws as they said they were doing earlier. I can't see whether they made any adjustments at the top of the spinner shot at the diverter, but I have also had no balls rattling up there.
The garage shot was still pretty clunky. Didn't look like they made any adjustments to it from earlier builds. I spent about an hour making iepinball's suggested modifications to the ball guide along the garage shot and now it shoots like butter. I highly recommend making the modification (see post #2300 of this thread). The most difficult part was getting the plastics off. It seems like Spooky drilled the holes for the plastics one size too small - they are stuck on there so tightly, at first I thought they must have been glued down. Took a lot of force to remove them, but luckily I didn't crack the plastic. I hope Spooky starts making the holes in the plastics a bit bigger, so we don't have to worry about cracking plastics when servicing the machine.
It's a beautiful machine. I'm glad Spooky is listening to customers and making adjustments. Well done!
**EDIT: Not sure what I was looking at the first time. There are actually two tabs on the spinner rail that aren't screwed in. The rail has no flex to it though. The arc of the rail has been changed. The holes in the empty tabs don't line up at all with the original screw holes. Sorry for the confusion in my post originally.
#3965 2 years ago
Quoted from Krsmith9:
Where are the new screws now, do you have photos?
#3966 2 years ago
Quoted from jonesjb:
I tried to just do exactly what iepinball did. Check out the photos in post 2300.
#3967 2 years ago
I tried to just do exactly what troz did. Check out the photos in post 2300.
I think he means the position of the screws in the spinner loop lane. If they are indeed screwed down. Glad to hear the loop shoots well.
#3968 2 years ago
Quoted from Manic:
Oh wow. I looked again and there are two screws that aren’t in. Not sure what I was looking at before... I’ll edit my original post. There is no flex to it though. The rail is bent to different angle. The tabs aren’t close to where the original holes are.
#3969 2 years ago
The garage shot was still pretty clunky. Didn't look like they made any adjustments to it from earlier builds. I spent about an hour making troz's suggested modifications to the ball guide along the garage shot and now it shoots like butter. I highly recommend making the modification (see post #2300 of this thread). The most difficult part was getting the plastics off. It seems like Spooky drilled the holes for the plastics one size too small - they are stuck on there so tightly, at first I thought they must have been glued down. Took a lot of force to remove them, but luckily I didn't crack the plastic. I hope Spooky starts making the holes in the plastics a bit bigger, so we don't have to worry about cracking plastics when servicing the machine.
**edit I don’t know what I was looking at the first time. There are two tabs that aren’t screwed down. The rail has no flex to it though. It’s been bent at a different arc. The original holes don’t line up with the empty tabs at all.
#3970 2 years ago
Quoted from Manic:
Here’s the current angle of shot. Can’t get a good pic of where the empty tabs line up without taking stuff apart. The rail is pushed back further from where it used to be.
#3971 2 years ago
Still working on the Gooblebox but the tessellated void is getting there.
#3972 2 years ago
Ah, so the inner orbit has the same holes, they just aren’t screwed in. This was the original change they mentioned of removing the two screws. I had thought you were saying the inner orbit is screwed into a completely different spot.
#3973 2 years ago
That’s what I thought when I first looked at it, but I was wrong. That said, the screw removal doesn’t appear to just be to “add some flex to the rail” as I had heard it before. The arc of the rail has definitely changed. It’s now pushed back beyond the artwork and if you look where the original holes are, the are well in front of where the empty tabs line up. They just didn’t drill new holes to fasten down the new arc. The rail is solid without those two tabs screwed down.
#3974 2 years ago
Yep that will work. Pushed back just behind the art Definitely changes and drastically improves that loop shot. Way cool company to take feedback and fine tune assembly. These games are great
#3975 2 years ago
Yes this is what had been described to me by Spooky so your comment threw me off. Glad they did it this way and kept the tabs on the rail "just in case" someone wants to tinker.
Awesome company with awesome people. The only company that seems to be able to easily navigate the minefield that is a pinball forum
Congrats on the machine you lucky SOB. I've got some painful waiting until the low 300's.
#3976 2 years ago
If anyone else is having extremely variable shooter lane ball speed check the clearance between the ball and the left wooden guide rail, just below the portal gun, mine was a cigarette paper away so the ball could touch it at times.
#3977 2 years ago
Quoted from Kevlar:
mine was a cigarette paper away[quoted image]
I like your unit of measurement.
#3978 2 years ago
Is there a list of know dimensions so far? I've come across 2 I haven't seen before today, the one where all the inserts are white and the strobe dimension.
#3979 2 years ago
Quoted from Kevlar:
....all the inserts are white....
Twilight Zone! :3
#3980 2 years ago
When the game actually ships do they send you a tracking number? Number 115 here and just want to make sure it’s not going to materialize while I’m out of town or something.
#3981 2 years ago
Quoted from TigerLaw:
Yes you will receive a tracking number!
#3982 2 years ago
Yeah I got a tracking number
#3983 2 years ago
First impression of the game on location (at Pinball Lounge in Oviedo Florida).
Very nice looking and well put together, great lights, sound was not turned up loud but I could hear it ok. The LCD looked fine to me.
I was able to make the shots ok except the direct shot to the portal (left orbit) was only able to make 2-3 times and seemed as if it wasn't going to make it to the top as if the flipper power was too low? A very tight window for that shot almost as if the shot is harder than all other shots in any pinball machine I have ever played. I almost want to say the machine had to be set up incorrectly because the shot was that difficult I did not look to check where the flipper was aligned which may have been the issue. Also could have been a learning curve because I didn't make the shot at all the first 2 games and made it maybe 3 times on the last 3 games.
The right ramp was wobbly/flimsy and the exit of that ramp was not smooth with a bounce back up before exit. I am not sure if this is typical but hopefully there is a solution that people will detail what can be adjusted.
I didn't get too far in the game but had a lot of fun started a few dimensions and a few adventures only 4-5 games. Didn't get the magnetic save to work but that was due to my slow reactions.
#3984 2 years ago
That is a sweet little lineup right there.
#3985 2 years ago
Quoted from rai:
I added a couple of pieces of beer seal foam to my right ramp which makes it flow much smoother but I'd be welcome to a more elegant solution if any molders have any ideas?
#3986 2 years ago
Quoted from MikeS:
I added a couple of pieces of beer seal foam to my right ramp which makes it flow much smoother but I'd be welcome to a more elegant solution if any molders have any ideas?[quoted image]
Hot Wheels has added crash pads at the end of their ramps however, spookys ramps are more rounded than square.
#3987 2 years ago
Quoted from MikeS:
I plan on trying something like this, a clear desk blotter cut into a 1 inch x 8 inch strip that I bend a as a ‘U’ around the base. What do others think?
amazon.com link »
#3988 2 years ago
Just got my game, #104. What a great game! Very impressed thus far. Looks great, amazingly creative layout, top notch theme integration. I am looking forward to more modes being added.
Thus far, I've adjusted the Hold strength of the lower flippers, as they were getting easily knocked down by the ball. I've adjusted the monitor setting to darken the black. And I increased the flipper strength of all flippers (+5 from their defaults). I leveled the game at 6.9 degrees, shooting for a bit steeper than the default, which is the way all of my games are set up. Has anyone made any other adjustments that they recommend?
I have heard that there are some recommended changes that make the left orbit (garage) shot easier? That would be nice. It's such a cool shot in theory, but almost impossible to hit.
Apparently, I posted this in the wrong thread initially. Now, it looks like I need to start reading through this thread. 80 pages! Appreciate any head start as far as which changes are the most important to focus on right away.
#3989 2 years ago
If your flippers are still getting knocked down adjust the eos's.
#3990 2 years ago
So I hadn't opened this thread in a month... 1000 frickin posts! (oh no!? 1000 seems high)
I slowly read through while downing coffee and french toast, sausage and eggs...
What a happy thread!!!
-mof
#3991 2 years ago
A couple of things I've noticed and appreciated. I love that if you hold Start and do a restart, it talks trash to you and sends you to Butt Land. I love that they included apron cards. Spooky previously took the approach that you had to make your own, and it was a pain.
#3992 2 years ago
Quoted from Russell:
Yours came with Apron cards? How about spare leds? Mine had neither. Just saying.
#3993 2 years ago
Quoted from MikeS:
What is beer seal foam? Google just gives me pics of foamy beer.
#3994 2 years ago
Quoted from BillySastard:
Pretty sure we can come up with a more elegant approach granted I have not observed an issue myself.
https://www.pinballlife.com/williamsballygottlieb-beer-seal.html
#3995 2 years ago
I took a quick video that shows the right ramp return with the beer seal in place and then i removed it to show the difference. Its pretty drastic.
#3996 2 years ago
Quoted from MikeS:
Wow, mine has none of that bounce back.
#3997 2 years ago
Quoted from MikeS:
Yep that’s a good bounce. Mine does nothing like that! Don’t recall, how steep is your playfield set to?? Seems like a single foam pad at the end would be enough to absorb the bounce.
#3998 2 years ago
Quoted from MikeS:
I agree, mine doesn’t have that bounce. What pitch is yours set at?
#3999 2 years ago
Quoted from dnapac:
I'm at 6.9. I wonder what's different then?
#4000 2 years ago
Quoted from MikeS:
I agree you did fix it however must be something wrong as the machine I played also had too much bounce back.
$ 259.99
Toppers
12,500 (OBO)
Reno, NV
The MOD Couple
Toys/Add-ons
$ 5.00
Pin Monk
Other
Game Room Info Shop
Toys/Add-ons
$ 399.95
Pin Stadium Pinball Mods
Led
Men
$ 159.99
Interactive Pinball Mods
Shooter rods
9,900 (Firm)
Huntsville, AL
$ 70.00
NinjaCamp Mods
Other
This page was printed from https://pinside.com/pinball/forum/topic/aw-jeez-official-rick-and-morty-club/page/80 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
