Quoted from jonesjb:
Perhaps I misunderstood. I read your recommendation to lower the lower guiderail, which makes sense. I was referring to the kink (in the blue rectangle), my interpretation was that this was already there/bent like that from shots to the right orbit. My guess is that the kink can't be good for inner orbits, irrespective of how the guiderail is orientated.
Or are you recommending that having the guiderail set like that would avoid the kink?[quoted image]
That guide rail is all one piece, kink and all. The kink no longer exists, again these are before photos.
Let me start over.
The "kink" in the guide was present when I removed the house to reveal the area. It's my theory that the high speed ball coming from the right garage shot, continuously slamming against the far right of the guide caused the kink. It's either that, or it came from Spooky that way.
Either way, balls from the right garage shot would hit the guide, stopping the ball from completing the loop into the garage.
Adjusting the guide so that the upper lane is wider, keeps the ball from hitting the guide and allows the right garage shot to complete the loop as intended.
The same adjustment narrows the lower lane, changing the ball's trajectory from a spinner loop shot, allowing it to completely miss the diverter, and complete the loop back to the upper right flipper, as intended.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
