I've had my hands in and on a few Rick and Morty's now, and I have to whole heartedly say that the game is fantastic!
It's very tough, but it's very fun and very addictive. I can't remember a game I've done the "just one more game" move, more than this one. It hands you your ass, and the only reasonable response is "thank you sir, may I have another?"
There are some adjustments that I recommend making to get shots dialed in on the early games. I'm hopeful that Spooky will take these and other suggestions and make improvements on future builds.
These are in addition to the left loop and left garage shot adjustments that Eric, Hilton, and others have made.
First is the right garage shot. For this, both ramps need to be removed, and the house removed as well. Seven screws total is all, so it's not bad.
With the house removed, the two metal guides in this photo should be adjusted down so the upper lane is as large as possible, and the lower, as small as possible. This significantly helps the garage shot.
Next is the turn-around loop guides on the right. In addition to the right ramp, remove the plastic covering the guides. Bend all the guide ends inward so they do not stick out beyond the rubbers. Also, I recommend removing the bottom rubber as noted in the photo. This will help with the garage shot and the turn-around loop shot.
After doing these adjustments to the games I've worked on, the shots are much less clunky.
I've made these suggestions and others directly to Spooky, and I'm hopeful they'll implement them in future builds.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
