Quoted from Shapeshifter:Is there a pdf of the complete explanation of the rules anywhere?
As for strategy, do people target the multipliers specifically and if so, when is a good time to have 4x going?
Also meseeks MB - is there a purpose to it? Can it be completed?
I don't think there is a PDF, but there are a few rules explanations and walkthroughs on YouTube. To get higher scores multipliers are key, at least in my experience, and the Megaseeds are the best way to do this. However, if you can activate enough Meeseeks to set off that multiball you get points for each blue lit shot, as well as you get the "Jerry bonus" at the end of the MB is you can hit the JERRY target toward the bottom of the family targets. Other things you can do to increase your score dramatically: complete adventures with GREEN stamps, when you fill the card each GREEN stamp is a multiplier on the chosen adventure (rick potion seems to get me the MOST points). Also, you should try for as many dimensions as possible (using the UR flipper if possible for most megaseeds). When you are in a dimension you can hit the family targets to enable mystery award and if you hit it during the dimension you can get "shake megaseed tree" and get even more.
There are endless ways to increase your score, but these are some of the techniques I use.
