(Topic ID: 257850)
Official Rick and Morty Club - You are not like other carbon based life forms.
By TheNoTrashCougar
2 years ago
  • 16,938 posts
  • 634 Pinsiders participating
  • Latest reply 58 minutes ago by Svente69
  • Topic is favorited by 325 Pinsiders
84 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 16,938 posts in this topic. You are on page 333 of 339.
11
#16601 45 days ago
I’m a procrastinator, but I finally installed the revised flipper bushings. I was pretty happy with how mine played already, but figured I should just go ahead and put them in. Doesn't feel too different, maybe a hair stronger now. I feel like I got some left ramp shots that would have rolled back before.
Anyway, still loving this game…it’s always fun! Even tho Godzilla is the new shiny, I’m still firing up my RAM! Bolted. Godzilla would leave first. For real.
#16602 45 days ago
Just fired up mine since a couple of days and it's crazy how you get into the shots over time. It develops flow and combos where there was none before. Absolutely love the game and slowly creeping up my GC
Let's see if Santa brings me the pinmonk fans
#16603 45 days ago
Quoted from Rarehero:
//<![CDATA[
window.__mirage2 = {petok:"294763697a3b2b2fc7b179fff80a319454fd13b6-1638399322-1800"};
I didn’t notice a difference with the new bushings, but my score have certainly increased. ~20m stock, ~45m with spacers, 93m with bushings
#16604 45 days ago
Is it possible to cut the bushing same as the new small bushing 1-3/8" from Spooky? if yes what would be the length to cut?
#16605 45 days ago
Quoted from pinballM:
The new Spooky bushings are 1.366" tall, which is just under 1-3/8". If you are going to modify the existing bushings just make sure to cut the extra off the long side. Also, make sure to ream the hole out so the flipper bat does not get hung up.
--Scott
#16606 45 days ago
Quoted from TheNoTrashCougar:
--Scott
Thanks for the tips
Hmm this is not on pinball life , only the bushing 1-3/8" is available
You know what is the difference between Spooky bushing and Williams/Bally Flipper bushing?
I have to check on my ACNC and RZ what is installed
#16607 45 days ago
Thanks for the tips
R&M has a thinner pf. The bushing were created specifically for it after the fact because it was found the normal bushings are too long. I would suggest contacting them and having them sent to you.
#16608 45 days ago
Here are the proper bushings. We rounded the product description to keep it simple.
https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PBL-300-0199-00
Thanks,
--Scott
#16609 45 days ago
Thanks,
--Scott
Wait, this was an issue on all spooky games? *scratches head*
#16610 44 days ago
Thanks for the tips
Just email Spooky & ask for a set. They’ll mail it to you for free.
#16611 44 days ago
Anyone have sound cut out on latest code randomly and rarely? My guess is something bugged with the added callouts.
#16612 43 days ago
Quoted from KingHebes:
Same here.
#16613 43 days ago
Yes. At first I thought this was a dimension mode feature that was new but realized that it is not. FYI seems to happen with me when combined with an active dimension.
#16614 43 days ago
Something weird happened to my game today as I moved it from the top floor of my house to the basement. The move was pretty straight-forward, no issues per se. I also had to remove the TOPPER because it wouldn't fit into the basement otherwise.
Anyway, everything went well, the game turns on, the screen turns on, the playfield lights, music and everything turn on....buuuuut the game doesn't turn on. Doh!
When I press START, literally nothing happens. I tried to go into the SETTINGS inside the door and nothing happened when I pressed on that as well, i.e. it doesn't turn on the SETTINGS menu.
Any suggestions? (ps: I'm not a DYIer, not very techie)
#16615 43 days ago
1) check the start button connections.
2) Check your ground ribbon. Make sure it didn’t come loose somewhere.
#16616 42 days ago
Fart Dimension with the Scary Terry Adventure sounds hilarious! This game's permutations keeps bringing new experiences!
#16617 41 days ago
My right flipper, launch button, and trough eject have stopped working. Is that all tied to 1 fuse? Not at home to check it out
#16618 41 days ago
Quoted from Morgoth00:
Looks like there is a 4amp fuse blown. I know my son likes to play holding on the flippers all the time for no reason.....
#16619 41 days ago
Yes, same fuse. 4A. I've been told you can take it up to 6A if the issue repeats itself.
#16620 40 days ago
I might be thinking to trade or sell my R&M BSE what's the going rate for low plays all mods (except butter)?
#16621 40 days ago
Quoted from rai:
It's subjective to condition and location etc.... but I have seen them as of late going between 12.5-16k, average is about 13.5K
#16622 40 days ago
Quoted from DeathHimself:
Going for? Or listed at?
#16623 40 days ago
Quoted from orlandu81:
Listing, sold is anywhere between 10 on the low side to 15k top side, with lots of sales between 11 to mid 13's.
#16624 40 days ago
Couldn’t get $9500 for mine locally in Northern California
#16625 40 days ago
Ended up potentially selling it it the bar but I don’t know if I wanna deal with any issues that may arise from heavy use
#16626 40 days ago
Yes, I'll lose the callouts until power-cycled.
#16627 39 days ago
Quick question. The RGB light on my pop bumper stopped working. I've had to solder it twice to fix. Now I think it is dead. Is this the part I need?
https://www.pinballlife.com/p3-roc-single-rgb-gi-pcb-assembly.html
#16628 39 days ago
Quoted from Palmer:
Nope you need this one
https://www.pinballlife.com/p-roc-rgb-pop-bumper-board-assembly.html
#16630 39 days ago
Also put 2 3/8-OD rubbers on the screw threads under the PCB. This will help isolate the shock to the PCB.
https://www.pinballlife.com/38-od-white-mini-post-rubbers.html
--Scott
#16631 38 days ago
So I’m about to rejoin the club. Missed mine. I’ve been out of it right when scary Terry mode was released. How has the code matured since?
I think it’s some of the best I’ve seen in the newer games. Not simple but not overly complicated
Also any must have mods recently released? I already got in in the pop bumper one
#16632 38 days ago
Quoted from delt31:
Limited maturing since sadly, but almost all bugs that I know of have been ironed out. Most of us are hoping for some more content at some point. Eric has eluded to it, but yet to see it.
Maybe a Christmas surprise!!!!
#16633 38 days ago
Most of the time I play I get the same modes to start an adventure....however, once in a while I will get a mode I haven't seen in a while. Is there a way to pick modes or know which one will come up when you start an adventure?
#16634 38 days ago
Quoted from insight75:
unless your in tournament mode, its randomized
-4
#16635 38 days ago
Guys, quit asking about adding new adventures and whatnot. We don’t want to ruffle any feathers to get told again that we should consider the game complete and be happy with what we got.
But keeping it a buck, can we talk about getting a few more Mortys added to the roster? Free the Mortys!
#16636 38 days ago
Quoted from DruTheFu:
I love R&M as it is, it’s a brilliant game. But I’d love to see more content. Hoping to see more is hardly ruffling feathers . Glad you see no issue with asking for more Morty’s
#16637 37 days ago
Quoted from delt31:
Since Scary Terry (or was this at the same update?) Rick potion number 9 which can only be the player choice as the 10th adventure.
And later a new adventure called Goodbye Moonmen was added.
#16638 37 days ago
After changing the bushings i had minimal improvement.
After realigning the flippers with ball guides I saw tremendous improvements in shot success.
Especially realigning the upper right ball guide that delivers to the flipper.
#16639 37 days ago
Quoted from rai:
When I do rick potion no 9 it stops my game midway and needs to be restarted
#16640 37 days ago
I'd love to see one more multiball mode.
#16641 37 days ago
Quoted from Sunsfan23:
Maybe re-install the newest code?
Never had these modes stop on me before... I've only had my pin get stuck in "attract mode" lightning during a game here and there, but once start a new mode or what have you, it gets out of that attract loop.
#16642 37 days ago
Down votes as expected. Feathers ruffled lol
Obviously against the Free the Nipple, I mean Free the Morty movement!
#16643 36 days ago
#16644 36 days ago
Could see a very nice small code feature yesterday. Had a ball jam on the shooter lane switch, a second ball was pushed in the lane.
Coil was not strong enough to shoot both balls out of the lane. So I thought I will have to pull the glass.
But the game code noticed the situation and turned up coil power as long as all balls were out. Nice, well done!
#16645 36 days ago
The game has been an absolute blast for me..heavy honeymoon phase, and that butter cabinet!!! Even for a cartoon theme, just unbelievably gorgeous.
Play the thing almost nightly...
Newb to the game question though...the whole antigravity magnet thing...reminds me of magna save in WCS....am I missing anything?
#16646 36 days ago
Quoted from MK6PIN:
Yeah so it’s not your typical magna save. You don’t want to hold button down. You want to tap/pulse it. You need to time it. It’s more anticipating a drain and having it fling the ball out. You’re not trying to use it to freeze the ball to drop it into the inlane like a traditional magna save.
#16647 36 days ago
Quoted from Palmer:
Ahh...suspected it behaved differently...appreciate the info !!( rarely read thru rules until I just get a feel for the game). That pop by the flipper can be wicked!!
#16648 35 days ago
It’s really something you just need to play with for awhile. You can also pull the ball out of the outline with a well timed pulse. It’s really awesome once you get the hang of it and then you’ll start doing phantom button presses on other games lol
#16649 35 days ago
Quoted from Palmer:
Nice!!!
#16650 35 days ago
Game code check:
rm-gamecode-20210810
the most current stable build?
