(Topic ID: 257850)
Official Rick and Morty Club - You are not like other carbon based life forms.
By TheNoTrashCougar
  • 19,606 posts
  • 708 Pinsiders participating
  • Latest reply 1 day ago by monitorpop
  • Topic is favorited by 333 Pinsiders
105 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 19,606 posts in this topic. You are on page 311 of 393.
#15501 1 year ago
Quoted from BowlingJim:
I would sell my standard for 20k.
I guess I would let my BSE go for $18,995....
#15502 1 year ago
I would sell my NIB (unopened) BSE for a lot less...
#15503 1 year ago
Quoted from lapean111:
Standards (or as I prefer to think of them, Space Black Edition (SBE)'s...) are WAAAAY rarer
Quoted from pinballinreno:
THAT'S NOT HOW PINFLATION WORKS MORTY
#15504 1 year ago
Quoted from ripple:
What's the story of where it came from. I was wondering if there would be any outside the 750 numbered edition # TEAM !
Mine falls in the Prototype/Spooky Teams category, yes outside the 750... It was one of a couple that were supposed to be sent to all the shows over the past year and a half...but we all know how that story ended up. So with no shows these were sold off, NIB...and that's where I came into the story. It has all the original issues but came with some pinball life gear to fix them. Still need to fix the flippers and tweak the shots.
#15505 1 year ago
Quoted from sheahan2:
Thats kinda cool.
#15506 1 year ago
Installed two new mods , DIY-Coil-Cooler and the new Leaf switches which scoot D. recommended.
The game feels much better now!
#15507 1 year ago
Quoted from MightyGrave:
new Leaf switches
I ordered some, I assume installation was simple. Any clearance issues, the space on the right side is very tight, but I imagine these are similar size. I definitely noticed the major difference in flipper buttons feel compared to all my other pins.
#15508 1 year ago
Quoted from Var1AbL3:
It's better and a Game changer but i Had to Cut a Bit from my Button to fit it
#15509 1 year ago
Has anyone seen a demo video how to install the replacement Mag switches in Rick and Morty. I am looking for a demo I go forth trying it.
#15510 1 year ago
Can you elaborate on how it's a game changer? This is the leaf switch for the flippers right? I've never noticed them being a problem but will definitely upgrade if they help the game feel better. Thanks!
#15511 1 year ago
Is this what you ordered for the right flipper?
https://www.pinballlife.com/stern-flipper-leaf-switch-double-contact.html
Quoted from dferg24:
R&M flippers feel a bit cheap and soft compared other flippers due to the fact that Spooky used switches without tension blades.
If you look at any other game, even my TNA, you will see that the switches all have an extra blade for tension. That gives you a more responsive feel to the flipper.
See the link above, and you'll notice right away what your current switches are missing.
I haven't installed mine yet (too lazy) but I plan to soon.
18
#15512 1 year ago
Yay, new screen arrived and got it all to fit. Working on some brackets now and I'll post up the details.
#15513 1 year ago
Quoted from harryhoudini:
Yay, new screen arrived and got it all to fit. Working on some brackets now and I'll post up the details. [quoted image]
Awesome buddy! Try it in a pitch black room and see how the blacks hold up... can't wait to hear about it (and then grab your pre-tested choices on Amazon
#15514 1 year ago
Quoted from Manic:
I'm going to start watching TV on this thing..
#15515 1 year ago
I'm going to start watching TV on this thing.. [quoted image]
Fill us in, where did you get it? Does it lose some of that gray at higher viewing angles?
#15516 1 year ago
Quit the torture dude! lol. Just spill your guts on every minute detail. We're a demanding bunch here!
#15517 1 year ago
Quoted from dts:
Looks pretty much the same from all angles. Deep black. I haven't touched the settings at all and it still has the protective plastic on it.
Quoted from Manic:
I didn't want to go telling people to buy as I just tossed it in there and hadn't done much testing since I just had it taped in place. It's all apart now as I'm printing brackets to get it to actually mount in there since it can't use the stock screen mount. It also needs a bracket to hold the controller PCB and it's keypad. I'll mess around with it this weekend and make a video on install if I get it all done.
Also, I noticed that it detected the resolution lower than what the screen and controller can handle so I wanted to check in to that before calling it good. I have a few other controllers I ordered that I can compare to and see if it is a limitation on the game hardware/software or a setting which we can't easily access/modify. Not that it needs more resolution but it's a 1920x1080 screen so might as well try to get that if it can.
#15518 1 year ago
Also, I noticed that it detected the resolution lower than what the screen and controller can handle so I wanted to check in to that before calling it good. I have a few other controllers I ordered that I can compare to and see if it is a limitation on the game hardware/software or a setting which we can't easily access/modify. Not that it needs more resolution but it's a 1920x1080 screen so might as well try to get that if it can.[quoted image][quoted image]
Ok now THAT'S an update. Appreciate it. You're right about the resolution so I can be calm now. Still pretty excited though
Usually little things that bug me but few others aren't going to get "fixed" but with you on the case I'm finally hopeful. Plus you've got the 3d printer and the know-how for the brackets ... AND... my gameplay on this beast has finally improved. Only took forever. Whole lotta cursing for the first few months. Glad my kids weren't around.
#15519 1 year ago
Ok 'fess up! Where did you get Scary Terry? ...and what is that frightening thing over the scoop?
#15520 1 year ago
Quoted from Manic:
Had found one in "ebay-kleinanzeigen" (e.g Craigslist) local and the scoop Thing is a Gromflomite Leg. Only for testing and fitting.
#15521 1 year ago
Quoted from Manic:
We have a pickle Rick and scary Terry figures coming soon to our store.
#15522 1 year ago
Call me crazy, but I would legit pass if someone offered me that for my game.
#15523 1 year ago
Here you can find pickle Rick for about $10
amazon.com link »
If you Google for scary Terry you will find him for about $ 30-50...
#15524 1 year ago
I think spooky uses 1366x768 for the resolution for this game. It’s set in the os level so you can’t change it. This is to decrease the GPu requirement and processing required if I recall. You won’t see much improvement at the higher res with this framework so it’s not necessary to use the full HD . Other games use this resolution too with the framework.
#15526 1 year ago
Stupid Question: What OS is this machine running? I'm embarrassed to say I haven't got a clue.
#15527 1 year ago
It's a custom Linux distribution
#15528 1 year ago
Quoted from luvthatapex2:
Thanks, good to know. It's detecting as 1280x720. Eric says 720p so that checks out. The other boards I bought won't work out anyhow due to subtle differences (mini-HDMI, usb-C power, etc) so the one I have is the best one I've found easily available.
#15529 1 year ago
Can’t wait for a parts list… thanks for doing this!
#15530 1 year ago
Quoted from gac:
Hi all- having an issue where the pop bumper has gradually stopped working after a bunch of games. A really hard shot to it might activate it but most balls just “thud” off of it. I know the nuts have not fallen off and I’m guessing it’s something with the spoon in the bumper mech. Just curious as to what others have done to remedy this. Thanks
This happens to me a lot as well. Some games it works fine, other games it doesn't register at all. Just THUDs, like you said.
#15531 1 year ago
Check your switch gap and while in there I would throughly clean the switch, and spoon.
#15532 1 year ago
Finally, as of today, I have no queue for R&M rollovers - you guys wore me out...but thank you...
Don't forget we do custom solutions as well - this was the very latest - a whole TOTAN MRS conversion - if you can believe it!
https://pinside.com/pinball/forum/topic/mrs-your-entire-pin-#post-6429460
Although one of your own here in the R&M club did swap out ALL of his rollovers recently....there were more than the usual 4 that folks typically purchase....
Matt
M&M Creations
13
#15533 1 year ago
Here are the details for the IPS LCD upgrade.
This is the screen and controller I purchased. You can use a similar 15.6" IPS LCD screen as long as it has a 30 pin connector and does not have the border along the bottom that most do. The plug must be within the borders of the screen and not sit below it or it will not fit. The similar part number is NV156FHM-N4H. They are available from AliExpress but the end cost isn't much less and shipping time made (as well as return policy) Amazon a no brainer for me. As far as the controller board, again a similar board will work as long as it supports HDMI input, 15.6" 1920x1080 IPS with a 30 pin connector and 12v power. I ordered several different options from Amazon and this was one of the few which met all those needs.
15.6" IPS LCD Screen Replacement: https://amzn.to/3itT4dS
HDMI LCD Controller Board: https://amzn.to/3jCR2rv
I created the mounting brackets and PCB support for the screen and controller linked above if you want to make it a plug and play install. It makes it a pretty easy swap. The original mounting frame can't be used to mount the new panel and controller. I'll make an install video which uses these brackets but will show you how to do the swap even if you're making your own or just taping the screen in place
https://pinballmods.co/rick-and-morty-pinball-mods/rick-morty-lcd-upgrade-ips-bracket
I tried to give a comparison shot. It's really worth the upgrade IMHO.
#15534 1 year ago
I will say, my screen looks NOTHING like what you show there (on the right).
#15535 1 year ago
Quoted from Zablon:
It was the best I had since I didn't bother taking a specific before pic. Can you post what you have from the side angle or from very high or low?
#15536 1 year ago
My original screen looks more like the upgrade, but pics are generally hard to capture screens. Maybe when you have time, some shots above the 6ft playing height would be helpful.
#15537 1 year ago
Quoted from dts:
I posted shots from multiple angles several posts back. It looks the same from all angles.
#15538 1 year ago
Quoted from Zablon:
Same here but remember everyones screens are in different dimensions!
#15539 1 year ago
Quoted from dts:
Mine is all good. I just turned the brightness down.
#15540 1 year ago
Oh, I missed that. It actually looked better from up high in your pics, strangely. Will take your word for it! I’m pretty happy with the adjustments to the original screen right now, but if I decide to get crazy may do the swap. Thanks!
#15541 1 year ago
Quoted from dts:
It's really not necessary for sure. Definitely in the "extra" category. I've changed out chrome locks for black on my JJP games because... extra.
#15542 1 year ago
Up and down yes there is some flux, but it actually gets darker, not lighter. But i have it dialed in for me since I'm going to be playing it 99% of the time.
I don't care about left or right...
#15543 1 year ago
Quoted from Zablon:
In a dark room with the contrast to 100 and the brightness to zero the blacks can get pretty grey for me. Now if I drop down 3 inches or so THEN they are nice and black. So it's a viewing angle thing that bugs me.
A good indicator is the final screen of the game before the match animations. It's just a small Morty badge on an all-black (grey for me at full height) screen.
Maybe most people don't play in pitch darkness or are a touch shorter... I know in a decently lighted room I wouldn't have an issue. But I like the light show in the dark so... I'm going to try the swap.
#15544 1 year ago
Swap, don’t swap. It’s not a competition. Do what looks best to you. The next guy may do different. Choices are good. I personally, have it dialed in for me.
#15545 1 year ago
Here’s the stock screen from a 6’5” view.
Blech!
The blacks start to match the Galaxian Purple, haha!
#15546 1 year ago
Quoted from Soulstoner:
Blech!
6'5"... damn you've got it worse than me or most everyone else. This may be the only time you wished you were shorter
I'm just glad there are options... if I hadn't grown so fond of this game I probably wouldn't bother.
#15547 1 year ago
I tried to give a comparison shot. It's really worth the upgrade IMHO. [quoted image][quoted image][quoted image]
Can you publish the maker files for 3D printing the brackets, please?
#15548 1 year ago
Quoted from Lounge:
He sells them. May not be ideal for him to give away his work.
#15549 1 year ago
Anyone run a bill validator?????
I’ve tried more than one Mars/MEI with bill stacked and they all hit the playfield on the way in to close the door. Any help appreciated, reward if ya sell me one that fits/works and takes 1s and 5s
#15550 1 year ago
Quoted from Brich:
How big of a bill cartridge are you using? You cannot use the 500 ones, and even the 300 ones are tight in some titles.
13,495 (OBO)
Milwaukee, WI
$ 6.00
Pin Monk
Other
12,500 (OBO)
Reno, NV
$ 399.95
Pin Stadium Pinball Mods
Led
The MOD Couple
Toys/Add-ons
$ 70.00
NinjaCamp Mods
Other
Trade
Machine - For Trade
Greenfield, WI
11,250 (OBO)
Kennewick, WA
$ 130.00
Dijohn
Decorations
$ 399.95
Led
$ 99.95
Shooter rods
$ 28.00
Pinball Mod Co.
Other
This page was printed from https://pinside.com/pinball/forum/topic/aw-jeez-official-rick-and-morty-club/page/311 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
