Quoted from Chisox:Cheers to your new game and birthday and also cheers on there being another 51 year old that owns this game and, I assume, loves this theme and show.
Oh yeah.. Been a fan since season 1. My daughter turned me on to it after a few episodes and I never looked back. Cheers!
So quick report after putting about 10 or more 4 player games on it tonight.
Flippers need adjustment like most others. I am getting knock back on both and the upper right occasionally wouldn't fire. Did a quick leaf bend and fixed the upper, need to play with the EOS for the lowers.
The launch power needs to be dialed up a little. Usually takes about 3 launches to get it on to the playfield. Incline set at 6.5
The meeseeks target needs to be moved to the left a touch. Already got a ball stuck behind it and under plastic.
The Beth, Jerry, Summer targets need a little adjustment to get them to register more. Only register on very hard shots right now.
Most of the shots are very clean and while hard, are makeable. I don't think I need to do much adjusting there. The center scoop works well with very few rejects. No adjustment needed there either.
Only thing I noticed that I need to look into is the left scoop from the portal shot does not exit clean and occasionally will bounce around instead of feeding the left flipper. I had it go down the left drain several times and had it bounce out of the left lanes to the center playfield area as well. Not sure whats going on there as everything appears lined up well, but haven't really inspected it because we all just wanted to play.
Had a fricken blast playing it tonight and everyone wanted to play "just one more" after each game. Game works very well and just needs a little dialing in. Luckily everything I need to do for the most part has been well documented by everyone in this thread. So easy stuff to do and I hope to tackle them this weekend along with the mods I have been hoarding away. That is if I can stop playing long enough to work on it.
Awesome job Spooky!!
