Great to hear. Thanks
Quoted from guitarded:
All 4 legs that I received were perfect.
Spooky is also including Pads in the box as well. But, there were no issues with impingement on any of the legs I received.
My legs were good on #504 that I received this past Friday. The extra pads were a nice touch, so I added them just to be safe.
Quoted from Pinball-Obsessed:
For me, I was just not getting consistent shots off that flipper. I know the shots are difficult but it was way to inconsistent. I’m not a professional pinball player by any means but I know I at least have some consistency in making shots. There were times I could make the upper loop multiple times (2/3 or up to even 5 times) and then there were times I couldn’t make the same shot even once in a game.
I did this late last night so I didn’t play that much or long after I made the adjustment but I did play a handful of games and noticed a huge improvement right away. I was making the loop and garage much more and I also noticed they were nice smooth clean shots. I’m glad I decided to make this adjustment and I hope I’m right about the improvement. Super excited to put a lot of games on it now and can’t wait to see how my scores improve!
I hope...
Did you notice any improvements in scores after you adjusted your rail???
Definitely improved scores. The ball hop of that rail and flipper made it really tough to control the ball (or even just drain down the middle)
Quoted from marspinball:
Is this a common place for the ball to hang up? Ball flew up from the right ramp.[quoted image]
Not sure if it’s common but if you get this mod from pinball life you won’t have to worry about ball hang ups there
https://www.pinballlife.com/rick-and-morty-pinball-blue-crystal-scoop-mod.html
Is there any way to increase the flipper hold strength on R&M? I have stiffened the right flipper button extender but the bottom flipper is still frequently knocked down with a hard ball return from the scoop. I love the game but feel robbed every time I get a drain from the flipper dropping while I am holding it. It seems to be getting worse over time.
Quoted from sataneatscheese:
Is there any way to increase the flipper hold strength on R&M? I have stiffened the right flipper button extender but the bottom flipper is still frequently knocked down with a hard ball return from the scoop. I love the game but feel robbed every time I get a drain from the flipper dropping while I am holding it. It seems to be getting worse over time.[quoted image]
In the settings under “coils” there will be a flipper hold strength adjustment. It follows the flipper coil strength(pulse) adjustment. Had to adjust mine as well, even after shaving the bushings down 1/8”.
Quoted from Backside_Slide:
I have not played with that adjustment at all and will check tonight. Thanks!
Adjusting the EoS on the flipper coils as far as I can tell has eliminated my knockdowns. You have to adjust them 'away' from the coils so that when you fully depress the rod the hook catch that hits the contacts doesn't make them connect until it is almost completely fully stopped. (I hope that makes sense?). There's a post in the key post that kind of shows it, but it isn't very clear if you've never messed with it before. Where this hits by default the rod travels another 3/16" or so after the contacts have connected (which apparently is too early).
Another thing to keep in mind is that if you get the two contacts TOO close, the flippers will stick up more, so keep close to an 1/8" between contacts. I'm still trying to adjust that out of mine now, but as I say the knockdowns have went away.
Why would they need to be close if it's about when contact is made and broken, couldn't just the outer leaf be adjusted out so that contact isn't made until the end of the stroke?
Quoted from fnord:
That's probably perfectly fine too.
After having no idea when mine was shipping I just got a call from fedex apologizing for the delay and it will be here tomorrow. Good times
Quoted from GrimDog:
What's your number ?
Quoted from melumga:
Has anyone else already destroyed their flipper rubbers? I haven't filed down my bushings. Waiting for Spooky to send some out.
Order some from PBL they are better
How many games did that take you?
I think Spooky uses PBL rubbers on all their games.
Quoted from Chisox:
Oops my bad!
I meant to say order the Superbands from PBL!
I have blue on mine and they look nice.
Thats great to see, what kind of pads are they sending with the game?
Quoted from wolv3:
Felt.
You got Felt!?
I just got 4 'Always' Pads.
Not even the ones with the wings...
Too bad it wasn't kotex they fit
You got Felt!?
legs are too far apart for wings...
You can also turn the scoop power level down. I think I dropped mine from 20 to 16 or so. Any lower it would start getting unpredictable so you'll have to fiddle with it a bit.
Beats having the scoop shoot the ball with such unnecessary force. My flippers were holding up but I could feel them groaning under the assault.
Quoted from Manic:
God it would be hilarious to have a shriek or some sound or swear when a flipper was hit hard enough knock down from a scoop shot and the flipper either recovered or didn't.
Quoted from brerspidur:
Audit says 155 games played. Had the game since November.
Oops my bad!
Pink titans FTW. I will post pics when it happens here.
Just did this and it made a huge difference! Changed from "medium" to "High" and its night and day. Thanks!
Quoted from toyotaboy:
#530 ready for pickup for those keeping track.. grabbing it on Thursday.
Congrats! Thanks for the update, that means they could be building my #543 any day now. Woowee!
Quoted from estrader:
Any of you guys receiving games lately butter cabs?
Not me. The #504 that I received Friday Feb 19th was regular cab.
Super excited.... Only about 30 or so away from getting my build sheet. It feels like Christmas is coming. Anyone else binge watch the show before getting their machine?
Who is the best distributor to get on the next spooky pin from? PM me if you don't want your secret distributor name getting out there.
482 with a butter cab was delivered Feb 12th, fyi
#458 w/ Butter arrived exactly 1 week ago...I am afraid to look and see how many games I have put up on it, already!
Quoted from gliebig:
^Don't forget to have fun. ^
I love that call-out because Rick seems to say it after I've had a couple really shitty games, so I'm like "FU Rick!"
Hi guys
I know it is a long shot, but is anyone interested in selling their 'yet to be produced pre-order deposit' , please PM me. Thanks in advance.
Quoted from EasternBloc:
R&M in the house and still no power from an ice storm 9 days ago.
Aw geez.... that sucks! I mean, I know there’s a lot going on over there because of the weather and there are worse things then this but WTF!
Screw your bad weather in Texas!!!!
Congrats and at least you have time to make sure everything is nice and tight, connected etc...
I complain with the perspective of knowing how fortunate I am to be able to have such a problem. I’ll enjoy it plenty once the local flooglebox is charged and that sweet sweet 110 starts flowing. Till then, if this is my biggest problem, life is sweet!
So how is Pickle Rick adventure qualified? I’ve noticed that it’s the only mode that starts when I shoot the garage.
Quoted from Jakers:
I think it may be random, but yes it starts with garage. I've had it come up almost immediately at the start of a game before. You will hear morty and rick telling you to go to the garage even though the portal isn't flashing.
