(Topic ID: 257850)
Official Rick and Morty Club - You are not like other carbon based life forms.
By TheNoTrashCougar
  • 19,606 posts
  • 708 Pinsiders participating
  • Latest reply 18 hours ago by monitorpop
  • Topic is favorited by 333 Pinsiders
105 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 19,606 posts in this topic. You are on page 190 of 393.
#9451 2 years ago
Quoted from PinMonk:
I like the way you think, I was the same way. The problem is since the right upper flipper is flipping in tandem with the lower flipper, it's getting hot as well. In addition to extreme heat, I have video of one just failing - it stops working at all - until it cooled a bit on the next ball because it got so hot (I don't know why as I only have the video, was it swollen from the heat? Dunno.). So that is a heretofore unknown issue to me. I didn't know they could stop working. Plus, I would think that over time 180F+ on the playfield is going to cook the wood and end up with something like magnet burn that will eventually show through to the top. So there are cosmetic concerns, too.
None of this is a problem if your sessions are 30 minutes or less because the extreme heat doesn't come into play. But if sessions are typically 60 minutes or more, definitely an issue, especially on Rick and Morty, which has the highest coil temps with long play of any machine I've tested so far.
How long was your test that caused the flipper to stop working? Seems like a big problem for R&M's in the wild (when they return to life post COVID).
Wonder if there are software/hardware tweaks that could help, since I've never heard of Stern/JJP/BW failing from heat exhaustion...
#9452 2 years ago
Quoted from snaroff:
That was sent to me, so I only know the temp was over 180F and the flipper stopped working temporarily.
I don't think it would be a problem (non working flipper) in the wild since the machine would have to be played non-stop for something like 90 minutes or more with no breaks, and that's not usually the way location pins go unless it's a hardcore pin player hangout.
Dunno, but it seems like there should be some way to help in software. I don't know if the P-Roc gives some kind of flipper pulse granularity, though. In all the (limited - a bit over 10 models) testing so far R&M by far has the highest 60 and 90 minute temps and is the only one where a flipper temporarily stopped working when it passed 180F (I'm trying to find the email, but I believe it was over 187F if I remember right).
#9453 2 years ago
Someone gave an in depth explanation why it seemed to be especially bad on R&M earlier in the thread.
#9454 2 years ago
Good point, but I had my LOTR in a high traffic free play arcade (where you pay an hourly rate) and it was getting over 1000 plays per week IIRC.
#9455 2 years ago
I would not put R&M in that environment without cooling for the flippers, for sure. But I would think that's a pretty extreme case.
#9456 2 years ago
Quoted from Zablon:
I also don't have a R&M so I can't test to see if hold pulses continue to raise coil temps when you trap, which is part of the heat puzzle, too. On Spike2 I was surprised to find that hold doesn't increase temps of the coil. I left it on hold for a half hour and only got one degree hotter. That's a complete (and welcome) departure from SAM/Whitestar.
#9457 2 years ago
Yo fellow Mortys! (Morties?)
Flippers sticking up occasionally- requiring a double tap.
Thought maybe was the bushing but shaved it down and checked play carefully and no resolution.
Thought maybe an issue with the flipper switches but can't seem to see any issue or get them stuck watching button taps with pf up.
Happens left and right lower about equally.
Anyone else? Did I miss a fix earlier in the thread?
Thx
Mike
#9458 2 years ago
Quoted from bitternerd:
Thx
Mike
NOT saying this is your fix but I had an issue with my Left flipper and for me it turned out the coil stop became magnetized. Once fixed never had an issue since.
#9459 2 years ago
Quoted from Yelobird:
Whoa. Come from factory like that? I think mine did it from day one. Will have to check. How did you even figure that out?
#9460 2 years ago
I pulled the stop and a paper clip stuck to it. No major honestly don’t remember what I did to demagnetize I think I Googled it. Also check the coil sleeve could just be pinched.
#9461 2 years ago
Good call. With how many stern coil stops i have replaced i should have looked there first. Doh.
#9462 2 years ago
Quoted from brerspidur:
You have to go to the spooky fan section, and then there are options for 2, 3. And 4
Have a link? I don't see a spooky fan section... search doesn't bring up any 3 or 4 options, neither does the R&M section.
#9463 2 years ago
Quoted from ninjedi:
https://pinside.com/pinball/market/shops/1170-pin-monk/04552-tibetan-breeze-spooky-pin-2-3-4-flipper-cooling-kits
#9464 2 years ago
Thx
Mike
I have the same issue with both of my lower flippers. I haven't had a chance to look into it yet though.
#9465 2 years ago
Game #404 arrived across the border in the great white yesterday! very happy to finally play this pin. this is my first NIB pin and 3rd overall, so I'm still a bit new to troubleshooting. The only issue I've noticed so far is the upper flipper has stopped flipping occasionally, then randomly started working again. I checked the solder and all seems well connected there. and the 2 stage flipper button seems fine as well. so I'm at a loss as to what it could be. its happened 3 times now, and for no longer then about 5min each time.
aside from that flipper issue I'm having a blast with it!
20201229_152834 (resized).jpg20201229_210700 (resized).jpg20201229_210732 (resized).jpg
#9466 2 years ago
Quoted from Vhex:
aside from that flipper issue I'm having a blast with it![quoted image][quoted image][quoted image]
Check Right flipper button and refer to the posts on this topic in this thread.
#9467 2 years ago
Thx
Mike
If the EOS switch is engaging at the very end of the flipper stroke the flipper may stick in the up position (this is a software thing). Try adjusting the leaf switch so it engages a bit sooner.
#9468 2 years ago
checked that out, its possible that's the problem, I did a similar fix as recommended; however I didn't need to use the head of the zipties since my gap wasn't as large as his. but so far so good.
I also added some zip tie along the glass channel to reduce the sub vibration, that thing really pumps when it hits at the same time as the shaker motor.
#9469 2 years ago
Ok, need some help. I am going to email spooky if I can't get it figured out. That being said, my left flipper crapped out. Switch test good coil test bad. Wire from board to coil good, coil has same ohms as lower right coil. Fuses on board good. Thinking its the transistor? But not sure, entertaining family and was hoping for a solution I might be able to fix. If anyone has ideas I would appreciate any help.
#9470 2 years ago
Quoted from TherealDroopy:
If you've got a multimeter, check the transistor for that coil, for sure.
https://pinwiki.com/wiki/index.php?title=General#Testing_a_Transistor.2C_Silicon_Controlled_Rectifier_.28SCR.29_or_Field_Effect_Transistor_.28FET.29
If you don't know which transistor goes to the flipper coil in question, you can brute force it and try them all looking for the one that reads bad.
And if you don't have the transistor to replace it, you can "borrow" one from a flasher or something else temporarily you won't miss and move that from where it is to the flipper position.
That said, if something else (short, etc) is causing the transistor to blow, you'll blow up the new or borrowed one, too.
#9471 2 years ago
Thank you for the link will try to dig into it tomorrow (technically today). Not sure about soldering on the board, got an email in to spooky also. If they will warranty it I would try my hand at it to get it going for new years party. I Might even have a transistor from an electronics kit laying around?
#9472 2 years ago
Thank you for the link will try to dig into it tomorrow. Not sure about soldering on the board, got an email in to spooky also. If they will warranty it I would try my hand at it to get it going for new years party. I Might even have a transistor from an electronics kit laying around?
I don't know what they're using, but you want to make sure whatever you replace it with (if it's indeed bad) is compatible. No need to multiply your problems.
#9473 2 years ago
Yes will definitely check for numbers or move one from a flasher as you suggested. Also the fan kit went in easy. Will have to see what the 3rd fan costs.
#9474 2 years ago
Quoted from jonesjb:
I solved this by putting a washer under the one side (under the playfield, closer to the center of the playfield), it will slightly tilt it and prevent the issue.
I decided to move my meeseeks target left...the right justified install on my game just looked "off". The new location looks more natural/centered and reduces the gap with the flipper considerably (which should prevent the ball from being trapped).
#9475 2 years ago
Def looks better, don't know why that is not how it's installed in the first place?...
#9476 2 years ago
Looks great! How did you do that? Did you drill holes?
#9477 2 years ago
Thanks! Correct...but I didn't use a drill
First, I used some "Alien Tape" to reposition the target without drilling new holes (to see if I liked the new location). Once I was happy with the new placement, I was fortunate there was enough distance for new holes (that didn't overlap with the old holes). On my game, the target placement was "off" by a lot IMHO. If it were only "off" slightly, it would have been much tougher to drill new holes without filling the old ones (which is a PITA).
#9478 2 years ago
Okay, after about 15 hours of play my ship hinge broke. Took it out (what a pain) and used a scavenged leaf spring from an old TZ standup target and created a proper flexible hinge. Ship motion works properly now. Will have to figure out something to cover the screws to clean up the visual look
#9479 2 years ago
Quoted from Coyohtay:
Seems like there have been enough reported cases of this part breaking that Spooky needs to address the issue. I believe there has even been reported cases of the the modified part available from PinballLife (https://www.pinballlife.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PBL-300-0185-00) breaking. And loosening the retaining screws is not a proper solution.
#9480 2 years ago
I'm trying to remain positive, but things like that really bug me. Why are these still being shipped out like that? It wasn't a good design to begin with, relying on bending plastic. As soon as people started reporting them breaking so fast, something should have been changed. Sure it may be a 'cheap' fix overall, but that is kind of the point. It screams 'cheap'. Hell, make it out of rubber if nothing else, it may dry out, but that will take years. People don't want to replace a broken plastic every month. (also, don't really make it out of rubber - add an actual hinge or something).
#9481 2 years ago
Quoted from Zablon:
I'm guessing that this issue never came up during testing, so Spooky assumed the engineering was fine. Most R&Ms have yet to have the part break (mine included), but I think by now there's enough evidence that the design or part needs to be changed. But if not, I've already ordered the backup from PinballLife, because with pinball, shit happens
#9482 2 years ago
Quoted from arzoo:
Seems like the PITA isn't the replacement cost, but the time to install it. Mine hasn't busted yet. I imagine the mech that pokes it might contribute to games where the plastics are breaking (if it's not adjusted properly). So if someone replaces the plastic, they should make sure the mech isn't poking it too aggressively.
#9483 2 years ago
I agree, and that may be why Spooky never had an issue during dev and testing - their test rigs had the mech adjusted correctly.
#9484 2 years ago
Is there a way to turn off the mech that shakes the spaceship? I do not need it to shake, especially if it might break.
#9485 2 years ago
Very nice!
Mine has not broken yet and creeping up on about 600 plays .
So I have a very important question for you… After you made this repair/modification did it get rid of the clunky sound that the original one made? I really don’t like the clunky sound that thing makes every time it hits the ship.
I mean it’s not the worst thing but it would be cool if your modified part makes that sound go away!
#9486 2 years ago
Oops! duplicated my post
#9487 2 years ago
Quoted from Pinstym:
I think someone mentioned it is tied to the up post in the horseshoe so can't be disabled
#9488 2 years ago
Quoted from PunkPin:
Maybe, but I imagine you can adjust the mech down to the point where it does nothing (or just taps it lightly).
#9489 2 years ago
The rod that pushes it can be cut down so that it doesn’t push it as high. Or I would think the push rod could be removed and the ship wouldn’t move at all.
#9490 2 years ago
No dice, still makes that sound. Seems like a mech noise. It did find a double nut loose inside the ship making noise as it bounced around, so less clunky, now just rattley
Quoted from Pinball-Obsessed:
Very nice!
#9491 2 years ago
Hi Mike,
I had this issue on my left flipper. Turned out to be a tiny bit of flash plastic on the housing the flipper button runs through. Xacto knife to trim the excess flash off the button housing and the flipper never gets stuck again.
Just enough flash for the flipper button to keep the leaf switch in contact.
Good luck.
#9492 2 years ago
Having an issue with some of the coils not firing. Neither the top or bottom flippers fire, the ball shoot coil, and the knocker. The left flipper does fire. Those are all i found so far, i'll start testing the rest.
Any ideas?
#9493 2 years ago
Quoted from Jherre6:
Any ideas?
Sounds like you blew one of the fuses.
Check the fuses on the boards in the backbox on the left where all the transistors are.
#9494 2 years ago
OOF. I’ve had my game for less than a week and now the upper flipper isn’t working anymore. Also getting consistent launch ball rejects on the wire form.. that or it goes sailing out into the back of the game.
#9495 2 years ago
Looking at the switch test these are open for some reason although looking at the switches they don’t look closed.
#9497 2 years ago
Two targets up, 4 balls in the trough, one captive ball. Seems right.
Did you pull the fuses on the boards with the transistors and check them with a multimeter. Losing a section of coils/flashers is usually a blown fuse.
#9498 2 years ago
Thanks... I was look on the pinmonk site.
Looks like no international shipping.
The international shipping is only on pinmonk.com, which only has the 2 flipper kit currently. I'll have the 3 flipper kit on there by this weekend.
#9499 2 years ago
You are just on top of things! Yeah blown fuse. Oh well. But I think I might know why the cooler was making noise. I’ll pm you. Thanks as always.
#9500 2 years ago
I know it's been discussed, but that type of plastic really isn't designed to flex. For the trouble of switching to a more elastic plastic, I have to suspect a piece of die-cut spring steel in the same shape, would work a lot better and last almost forever. To preserve cosmetics they could laminate it with a mylar sticker of the same art currently beneath the transparent part.
Speaking of mylar... has anyone tried laminating a broken part with some mylar strips, or even thick clear packing tape, to see if that would work any better? Thin strips of mylar might make a decent hinge where the range of motion is pretty limited. Certainly couldn't hurt to try this if the original breaks and you don't have a spare. You'd have to laminate both sides of the part across the break... with a small gap between them to allow the laminate "hinges" to flex without forcing the bottom one to stretch (the bottom would flex upward; the top would compress into the gap; both would be needed to keep the parts aligned and prevent the mech/ship from simply flopping over & getting stuck).
$ 99.95
Shooter rods
Precision Pinball prod.
Flipper parts
$ 300.00
$ 299.95
Pin Stadium Pinball Mods
Led
9,500 (OBO)
Bethlehem, PA
13,000 (OBO)
Osage Beach, MO
$ 25.50
The MOD Couple
Toys/Add-ons
Pin Monk
Other
Pinball Mod Co.
Other
$ 399.95
Led
This page was printed from https://pinside.com/pinball/forum/topic/aw-jeez-official-rick-and-morty-club/page/190 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
