(Topic ID: 257850)
Official Rick and Morty Club - You are not like other carbon based life forms.
By TheNoTrashCougar
  • 20,219 posts
  • 742 Pinsiders participating
  • Latest reply 47 hours ago by Jigz
  • Topic is favorited by 333 Pinsiders
b5f006fa-9417-42d1-8730-250ad8488fb6.__CR0,0,1080,1080_PT0_SX300_V1___ (resized).jpg
106 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 20,219 posts in this topic. You are on page 181 of 405.
#9001 3 years ago
Quoted from snaroff:
Just figured out why my right flipper is weak. Since other folks have complained about trouble making the left ramp consistently, wanted to post what I found.
As you can see, my right flipper is sitting lower than my left flipper (which is causing some subtle binding).
Turns out, the base of my right flipper is blocked by the digital display, which is why it's not flush with the PF. This causes the flipper mech/bushing to sit too low, which is effecting the power/operation.
I'm waiting for Spooky folks to advise on the best solution. I don't feel comfortable moving the display and moving the flipper mech is a big deal.
Can't wait to get this nailed...the game is hard enough without a wonky right flipper That left ramp is steep enough...
Nice job tracking that down. Hopefully there's some room for adjustment? I took a look at mine and it is definitely close.
#9002 3 years ago
Quoted from MikeS:
Nice job tracking that down. Hopefully there's some room for adjustment? I took a look at mine and it is definitely close.[quoted image]
Your photo shows me what's different. Look how your display has the acrylic base removed/missing from the flipper screws. Compare it with mine...see the difference? What # is yours?
#9003 3 years ago
You're right. Mine is #89.
#9004 3 years ago
Quoted from MikeS:
Yep, since your digital display board is different than mine (to apparently accommodate the flipper screws), I'm waiting for Spooky to advise me on this.
My gut says neither the display or the flipper can be moved. Don't know if they modify the digital display board during build or they have different revisions? My game is #175.
Thanks goodness this is a hobby for me (and I enjoy hunting these bugs). If I were just a "Rick and Morty" fan with no pinball chops, life with this game would be more discouraging. Fortunately, I still love it. As long as Spooky folks continue to support me, all is good...
#9005 3 years ago
Pinside to the rescue yet again.
I've always maintained that the pinball owner hobby is similar to owning a British motorcycle. There is a saying "Triumph - How to turn a motorcycle enthusiast into a mechanic."
Me, i owned BSAs, but may as well be the same thing.
#9006 3 years ago
I seemed to have eliminated my left ramp woes and thought I'd share in case anyone is in a similar spot. After comparing pics of others' flipper alignment, I lowered my right flipper a bit. It was just a bit higher than the left and was causing my shots to mostly hit the metal flap on the right side of the left ramp entrance. I tested by taking the glass off and firing cradled shots from the right flipper many times.
Now, my flippers both sit in relatively symmetrical positions, and that left ramp is a much more possible shot. I can finally make it from a trapped position and damn, it feels good to have it dialed in. The best part is I didn't have to up the flipper power at all, it's still on the default 30. It was a very minute change in where the flipper was sitting, but I think with how tight the left ramp shot is, it makes a big difference.
Taking the trough off was only mildy frustrating due to my screw driver having a fat handle and not fitting in tight spaces well, but after that, wrenching the bolt to loosen and tighten the thing holding the flipper was easy.
I also installed Pinmonk's coil coolers today, and they are awesome! I highly recommend them to anyone who likes to play longer sessions. They are simple to install and offer surprising cooling for the compact size of the fans. I put the fuzzy tape from pinball life on the glass and turned up the bass! Only thing rattling I can hear is the hanging quarter return doors, so I just shoved a microfiber towel in for now til I put little sticker pad things in. My machine is really rocking now!
#9007 3 years ago
I think you should be able to remove the flipper mech and then drop the display board. If you were able to grind off about 1/8” or 1/4” inch of the acrylic from the display board where it touches, that would probably solve the issue. A dremel tool or file would do the trick...
#9008 3 years ago
I'm glad to hear that you appear to have located the issue. I was thinking about you this afternoon when I was playing my R&M and was paying more attention to my left ramp shots...I make them with such ease, the ball sometimes can really go flying up and around to the upper flipper at speed.
On another issue, when I hit the right orbit shot to the garage, the ball sometimes goes so fast through there that it skips right over the hole and comes back down. I'm sure that this happens to everyone to one degree or another, but it really seems to happen more often than I think it should. Maybe 20% of the time.
Is there anything that can be done about this? Seems like the options to fix this would be pretty limited.
#9009 3 years ago
Quoted from RobT:
Knock down your left flipper power a few ticks?
#9010 3 years ago
Quoted from Pinstym:
I have experienced this at least once since updating. Never before the update.
I am dealing with a maddening issue for about a week now (prior code and new code) where almost every ball in play is ending with a phantom drain. Ball is rolling around the playfield, flippers die, bonus added. Next ball begins and most of the time a second ball is autoplunged into play. Like the machine has lost count.
Seems like a simple trough switch issue, but I can't figure it out. Everything looks good, switch test while pounding on the pf shows nothing. I even turned the shaker off, reseated the trough connector, and added new balls.
Maybe my issue has something to do with that 2nd trough that gets fed from the garage? Hopefully I get it figured out soon.
My problem appears to have been the connector was loose for the top left opto in the ship/lock. Reseated and played around 2 hours issue free tonight.
Love this game.
#9011 3 years ago
Quoted from RobT:
This has also happened to me but only a couple times. I am at factory flipper settings. Just figured it was a fluke?
#9012 3 years ago
Quoted from BlueIrocGuy:
Just a thought... plastic spacer isn't wrong way up? . It looks to be sitting on the spacer not on the board?.
Is the recess in the mounting spacer found on another corner perhaps??
Mine has cutout for flipper base there as well, game was built in August.
#9013 3 years ago
December 6th - Received 435’s option sheet and was returned same day. Shaking with excitement, waiting to hear back so I can pay the final invoice!
#9014 3 years ago
Congrats to the Spooky team, nearly to 500 even with covid. Is it too soon to start the next game speculation?
Anyway Merry Christmas to all at Spooky.
Message from the Freeeek Kingdom.
#9015 3 years ago
Quoted from thescottiep:
Going by this, less than 300 to go for mine Didn't I see somewhere that someone created a tracker for the number they might be on? I also think I read that some of the higher numbers were all ready made that they shipped outside the US? I could be wrong (probably am), so they may be over 500 made to date...?
#9016 3 years ago
Quoted from MikeS:
I haven't heard back from Luke yet (must be busy), but your photo gave me enough info to understand the fix (which apparently Spooky did on your game, since you haven't modified this).
I just clipped off the part of the plastic display riser that was getting in the way of the flipper base. Now the flipper mechanism sits flush
Unfortunately, I can't report a night/day difference in power at the moment. Seems about 10-20% stronger? Hard to know until I do more testing.
Also unfortunately, now that it's flush, I still notice a significant difference in the height of the flippers. Notice the significant difference with my Avengers flippers. The other *really odd* difference (with all my other games) is now high the RAM flippers sit! On all my other games, the sweet spot of the ball hits the center of the flipper rubber (what you'd expect). On my RAM, the sweet spot of the ball hits the lowermost part of the flipper rubber. This might explain why the Spooky flippers feel so odd to me...the height just seems wrong! See photos for detail on everything I'm talking about.
IMG_2914 (resized).jpegIMG_2914 (resized).jpegIMG_2916 (resized).jpegIMG_2916 (resized).jpegIMG_2919 (resized).jpegIMG_2919 (resized).jpegIMG_2926 (resized).jpegIMG_2926 (resized).jpegIMG_2928 (resized).jpegIMG_2928 (resized).jpegIMG_2931 (resized).jpegIMG_2931 (resized).jpegIMG_2934 (resized).jpegIMG_2934 (resized).jpeg
#9017 3 years ago
Also unfortunately, now that it's flush, I still notice a significant difference in the height of the flippers. Notice the significant difference with my Avengers flippers. The other *really odd* difference (with all my other games) is now high the RAM flippers sit! On all my other games, the sweet spot of the ball hits the center of the flipper rubber (what you'd expect). On my RAM, the sweet spot of the ball hits the lowermost part of the flipper rubber. This might explain why the Spooky flippers feel so odd to me...the height just seems wrong! See photos for detail on everything I'm talking about.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Thats great that you were able to resolve the issue with the base not sitting flush. I took a look at my flippers and they definitely sit a bit higher than my Stern games. I wonder if this could be resolved by using a different bushing? I haven't noticed any issues in my game with it sitting higher. If its hitting higher in the ball that would likely help with preventing airballs but may sacrifice a small bit of power since its hitting higher on the ball? I'd be interested to hear if anyone else has thoughts on this.
#9018 3 years ago
Quoted from MikeS:
Thats great that you were able to resolve the issue with the base not sitting flush. I took a look at my flippers and they definitely sit a bit higher than my Stern games. I wonder if this could be resolved by using a different bushing? I haven't noticed any issues in my game with it sitting higher. If its hitting higher in the ball that would likely help with preventing airballs but may sacrifice a small bit of power since its hitting higher on the ball? I'd be interested to hear if anyone else has thoughts on this. [quoted image]
It's more than a bit if you look closely at the photos I posted. It's quite significant...on my machine, at least. Can you snap a photo of where the ball hits on your flipper? Looks a bit lower than mine, but it's hard to tell.
It's also relevant to note that where the ball gets struck statically is different than where it gets struck when you fire the coil. That's why it's important to provide that 1/8" gap to give the flipper room to move (and not bind). So...if the lower part of the rubber is striking the ball statically, it could be 1/8" lower when the flipper is actually fired.
Intuitively, it just seems important for the sweet spot of the flipper/rubber to hit the sweet spot of the ball to get the most power/accuracy...no?
#9019 3 years ago
swap the bushings is my honest opinion.
Ball should hit square on the sweet spot. Too high or too low is less than optimal.
I also find that too high causes more torsional friction capability.
#9020 3 years ago
Quoted from Whysnow:
Well you should be able to loosen the flipper bats under the PF and adjust the height by lowering or raising them. They should fully down and then with a credit card's width of gap left between the bottom of the flipper and the top of the bushing.
I would start there, they might just be set a little high currently.
#9021 3 years ago
Right after seeing your bushings post 3 days ago, I emailed Scott/Terry @ PBL (before noticing the build botch I've posted about). Scott said the bushing are in spec with the original Williams flipper mechs.
I totally agree with you...ball should hit square on the sweet spot!! So...what bushings do I need to make this happen? Do you have a link?
Quoted from Fytr:
That doesn't make sense. The flipper bushings are simply too high. If they are too high, it's impossible to lower the flippers.
#9022 3 years ago
That doesn't make sense. The flipper bushing are simply too high. If they are too high, it's impossible to lower them.
I must be misunderstanding the issue. I thought the gap between the flipper and playfield could be adjusted, isn’t there even a tool for this...
F7EACC25-2D17-4C3A-AC50-DAF00C45E2FF (resized).jpegF7EACC25-2D17-4C3A-AC50-DAF00C45E2FF (resized).jpeg
#9023 3 years ago
Difference in PF thickness between WMS and Spooky?
#9024 3 years ago
Quoted from jonesjb:
I must be misunderstanding the issue. I thought the gap between the flipper and playfield could be adjusted, isn’t there even a tool for this?
You are misunderstanding the issue. Do you have experience rebuilding (or working on) flippers. If not, then it's not surprising you are misunderstanding.
The gap can certainly be adjusted, however the flipper rests on the bushing, which is the absolute low point for the flipper.
#9025 3 years ago
Quoted from Fytr:
this is a good call. After looking at his pictures again, his bats are sitting proud over the top of the bushing.
That is a good first step and see.
I personally dont like the bushing height on a bunch of games that have come out recently. I think something changed slightly at the main place that makes the bushings. They are for sure in spec, but slightly lower is better.
I unfortunately dont know the exact ones to order as I keep a stock of like 6 different bushings and just eyeball it/ compare to what I pull out of a game.
#9026 3 years ago
Quoted from epthegeek:
likely some difference is my guess of root cause.
Hence why these are in spec but slightly taller on pf side
#9027 3 years ago
My flippers are resting on the bushing. Don't know what you are seeing.
#9028 3 years ago
No need to be testy. *If* the flippers are already resting on the top of the bushing, then yes, obviously they can't be lowered further. That is an assumption at this point.
On my game, I adjusted the flippers as soon as I saw the odd flipper angle they had set them at at the factory and made sure they had plenty of "slack" vertically when I tightened them down. I have no problem with the left ramp shot.
#9029 3 years ago
looks to be sitting high/ over top of bushing?
#9030 3 years ago
snaroff is right. The bushings do sit too high. I tried to lower my flippers also and was not able to. Mine look exactly like his pics.
#9031 3 years ago
Sorry, can't be lowered any more (and has the 1/8) recommended gap when I pull up on the flipper.
Quoted from Fytr:
I wasn't being "testy". jonesjb *asked* if he was misunderstanding the issue and I said he was. I'm trying to help by putting this info out here. I can take it all private if you'd prefer (now that was testy
Exactly. I don't have my BW machines at this location, but I just checked my JJP/DI (which I believe uses the same flippers as Spooky?). The PF is indeed 1/8" thicker than my RAM PF (and the flipper strikes the ball in the proper location).
At this point, it's clear to me that Spooky (or PBL) simply needs to advise us on what bushings would lower the flipper 1/8". The flippers just aren't hitting the ball optimally...I'm convinced of this.
#9032 3 years ago
This would also explain why the flipper rubbers get destroyed so easily - the ball is only hitting the lower edge of the rubber.
Screenshot 2020-11-11 145226 (resized).pngScreenshot 2020-11-11 145226 (resized).png
#9033 3 years ago
Can washers be installed below the playfield in-between the entire flipper and coil metal bracket they are attached to? To pull the entire assembly away or down? To bring the flippers closer to the playfield?
#9034 3 years ago
Quoted from Pinball-Obsessed:
washers can vary in thickness and may be hard to find some that fit. An acrylic shim may work better to make up for the 1/8".
But likely needs to be laser cut.
#9035 3 years ago
The flipper bushing is screwed directly to the bottom of the pf (it's not part of the flipper mech). Maybe could add washers, but that seems janky.
#9036 3 years ago
they could, but much easier to just replace the bushing
#9037 3 years ago
Quoted from arzoo:
Flipper bushing is part of the flipper mech... Never seen one ever screwed to pf. It is integral to the whole mech.
Just loose the flipper bat, drop the whole mech, and rebuld the flipper with a new (shorter) height bushing.
This is like a 20 min job for a novice IME
#9038 3 years ago
My bad, you are correct. Maybe I'm thinking of older EMs?
#9039 3 years ago
Quoted from arzoo:
Exactly...which doesn't happen on any of my other games.
Quoted from Morinack:
I've talked to folks about this and it's problematic. I think the ball needs to be in Spooky's "court" to advise on this issue. Adhoc solutions for this part of the game (which get's pounded) isn't something I'm going to fiddle with.
#9040 3 years ago
In any case, this "flipper-bushing gate" issue isn't the reason the original poster can't make his left ramp consistently. I have no issues on my game and i have the same bushings as everybody else.
#9041 3 years ago
Quoted from Fytr:
Agree, and knock on wood. 2 hours playing last night and making ramp shots was no issue. Factory settings on flipper power.
#9042 3 years ago
Buy a set of replacement bushings and take some sandpaper to the top (Portion that sits above the PF).
Should be able to drop your flippers as low as you want in under 5 minutes. 2 if you have a belt/table sander.
Good News re. #458 : Options are IN!
#9043 3 years ago
Quoted from Fytr:
Not sure I totally agree, I would think the combination of a difficult shot off the flipper tip and only using the lower edge of the rubber could in some cases make the shot much harder imo.
#9044 3 years ago
I personally think that the game is good as-is and they wont be (nor should need to) change anything.
Like many things in the owners thread, they get blown up when reality is that these are personal adjustments to improve on an already great game.
If you want to tune it in... just rebuild your flippers and change your bushing.
As Scott noted, the bushings are in spec.
Simple fix... lower the flipper rubber on your bat slightly to get a more square hit on the sweet spot of the ball.
#9045 3 years ago
Quoted from arzoo:
Yep. In fact, from "day 1", I've thought the flippers have felt odd. Now that I see where the ball is being hit, I'm not surprised. I'm convinced that it's important for the sweet spot of the bat/rubber to hit the sweet spot of the ball. Striking the ball at the lower tip of the rubber just can't lead to better ball control/placement. It's not just about power.
JJP uses the same flipper mech I believe. Here is an A/B between RAM and DI. As I mentioned above, it's because the DI PF is 1/8" thicker than the RAM PF.
You are pretty inconsistent, since 3 days ago you told people to swap out the bushing if they were having flipper issues.
IMG_2934 (resized).jpegIMG_2934 (resized).jpegIMG_2935 (resized).jpegIMG_2935 (resized).jpeg
#9046 3 years ago
Take the bushings out and sand/trim them down to your preferred height.
Problem solved in less time than it takes to photograph pics of your other machines.
#9047 3 years ago
Quoted from guitarded:
So incredibly false...taking off flipper bushings is much more work than taking a photo of a flipper/ball.
If you don't know that, you've never done it. Or...you just like being cute.
-14
#9048 3 years ago
I can have the flipper bats out of a machine with the glass off of it before you can find a place to set your glass down from your second machine.
6 Screws and I am running the bushings on my table sander in under a minute.
...all while you are trying not to fumble your phone/camera so you can take a picture of you holding a ball in front of your flipper bat.
Because you are apparently too stupid to set it in place (try some BlueTack, or set it inside a small washer) for a photograph that you can post online to accompany your whinging bitchfest.
I gave you a solution. Either fix it or don't. Buy stop whining.
#9049 3 years ago
Rule #1 - for everyone, be nice. It's Christmas, be helpful, positive and not bitchy. I love this thread, good helpful ideas and comradery is soooo much better
#9050 3 years ago
Santa is watching!
$ 29.90
The MOD Couple
The MOD Couple
$ 60.00
Pinhead mods
The MOD Couple
10,500 (OBO)
Phoenix, AZ
$ 50.00
Duke Pinball
10,500
Merritt Island, FL
$ 39.50
The MOD Couple
11,000
La Porte, IN
Pinhead mods
$ 130.00
Dijohn
$ 299.95
Pin Stadium Pinball Mods
$ 28.00
Pinball Mod Co.
Filament Printing
$ 65.00
Pinball Mod Co.
$ 399.00
Bent Mods
$ 45.00
Pinball Mod Co.
Game Room Info Shop
Game Room Info Shop
$ 25.50
The MOD Couple
$ 34.00
Pinball Mod Co.
$ 85.00
Pinball Mod Co.
This page was printed from https://pinside.com/pinball/forum/topic/aw-jeez-official-rick-and-morty-club/page/181 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
