Forgot to mention that Jerry Edition #231 arrived last Thursday (11/5), and honestly, I've been too busy playing to post. I guess that's really how it should be.
The 'Awww Geez':
- Pin suffered damage somehow in transit, like a lift ran through the corner of the box. The damage suffered was a portion of scratched off decal and underlying wood chunk damage to the left panel of the 'Morty' side of the backbox.
- On the topper, the portal plastic piece's flat screw tip would not clamp down to the flat portion of the rod that spins on the topper motor. It was like turning a stripped screw. I was able to make it work by having the screw down just enough to cause added friction to make it feel like a snug, tight fit. The portal hasn't fallen back off yet....fingers crossed.
- The game wouldn't fully boot out of the box. Received the "Hardware connection failed. Ensure boards have power and USB cable is secure." I spent a good almost hour trying to correct this. Checking cable connections, switching the SATA hard drive cable, inserting the SATA cable into different SATA slots on the motherboard. While doing those SATA cable swaps, I noticed that the middle board in the backbox didn't seem to light up like the boards to its left. Lightbulb moment, it must not be getting power. Searching the backbox for a loose connector, searching under the playfield, removing the black plastic conduit from the wire strand feeding the rest of the specific board (and having to stuff the cable strands back into it, ugh).....NOTHING. "Let me check this OTHER black plastic conduit feeding the OTHER boards." Boom bitches, loose power cable finally located, we're finally in business!
The "Let's Lick Tits":
- What can I say about my customer experience, other than that Joe at Pinballstar, and the team at Spooky, will make things right. They all know and realize we spend a shit ton of money on the machines, and they work to help make the purchase as satisfying as possible. Prior to delivery, I received an email from Joe saying to make sure to inspect the delivery closely, that there have been a small number of reports of various types of damage suffered during the shipping process. I did just that, even having a live text conversation after discovering the damage to JE 231, making the delivery guy post down in my driveway for a decent amount of time until we figured out a plan. Joe sprung into action, and working with Spooky, they/we agreed on an acceptable solution. Sure it would of been my preference for JE 231 to have arrived in pristine perfection, but shit happens. Even though I was super bummed with the initial situation, I didn't come at Joe in a dickish way, and through communications, we worked it out. I've learned a long time ago that passing the personality test can get you a lot further than ***burp*** being an asshole about it.
- So far, no cabinet decal damage. Could be overkill, but from the get go with installing my legs, I layered felt pads under light blue plastic Pinball Life leg protectors under the actual legs. The light blue protectors actually add a nice accent to the blues of the cabinet decals. I can see a decent amount of clearance between the legs and the decal to keep the dogs at bay. I've had my share of plumbus warnings, but I'm not one to really wrestle my machine into submission.
- After reading the complaints about the glass rattle, I figured I'd take care of it before it was really a thing. While initially setting up the machine, I adjusted the sub volume on the amp as recommended, and after the first night of playing (Who really wants to work on a pin instead of flipping it on the first night? Am I right?), I added 'Tesa Black Fuzzy Fleece Tape' to the edges of the glass. The glass rattle is pretty non-existent from what I'm hearing, with clean bass and sound.
- Spooky recommends 6.5 degrees, Scott previously mentioned 6.9 degrees. I set mine to 6.7 degrees, and it plays to my liking.
- This game can be fast and extremely fun. This game can be fast and layeth the smacketh down. All I know is I keep hitting Start, and the only time I can ever get any alone time with this pin is when my two sons are asleep. In just a week of playing, I'm the Mortiest Morty on my machine with over 10million, and have 6 combos made.
If you're still waiting for your R&M, and are on the fence on whether you should bail while you can, DON'T DO IT! Me and my kids are all pre-pin Rick and Morty fans from Season 01, and this game is so worth the wait. We've all heard that more is coming in the way of code, and I'm juiced for that, but even in state that the pin is in today, I can't see this pin exiting my Gold Mine 2.DRU garagecade.
