(Topic ID: 301823)
Avengers Premium Issues
By SilverballGamer
54 days ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 32 days ago by PaulRiccardi
    #1 54 days ago
    Hello all, early this year I bought an Avengers Premium. However, I have been experiencing a few issues with it, and I was hoping that someone on here might know how to figure some of these out.
    1. The portal lock opto is inconsistent. This is probably my biggest issue, as sometimes I will be hitting the shot up to 4-5 times, and it will just keep going straight through the subway, rejecting it. I’m assuming it’s a bad opto, and if so, is it a specific kind? And where can I get it?
    2. The Avengers tower magnetic keeps holding ball after it’s supposed to let go sometimes. Instead of doing it automatically, you have to press a flipper button for it to let go. I feel like this might be an easy fix, however, I don’t know how to solve it.
    3. The Auto-Plunge is often too weak to get up the right loop/ramp. If you are wondering, it is set to max power, so the problem lies somewhere else.
    That’s all. Any answers or just interest is greatly appreciated. Thank you, and have a great day.
    #2 54 days ago
    I can help u with #3.. look to see if the ball is sitting flat on both sides of the auto plunge. If not I think it doesn't hit the ball clean and rattles and spins out. I pulled mine out, tapped it will a hammer careful to close the gap. Ball sits flush. Makes it well over 95% of the time now.
    #3 53 days ago
    Thank you for the response! Attached is how the ball sits on the auto plunge. Is it bent in the way you imagine? And if so, how should I hammer it?Thank you!
    #4 52 days ago
    With a C-clamp you'll have more control, IMO
    #5 51 days ago
    I think I’ve solved the auto plunge issue: it just needed it’s power to be lowered. Still not sure about the other two issues though.
    #6 32 days ago
    I’m having a strange issue with mine. Normally it registers when a ball drains. But when I’m in a gem quest or multi ball It doesn’t. So I lose my ball and the quest continues. I have to open the coin door and manually pop a ball out. Anyone else having this issue?
