1) really hard to play…
2) ok, I got 40M finally, so one of 10 not bad…
3) ok, this is the only machine I own that I'm screaming at when I miss a shot and the final ball drains….Love it.
Can't decide if the music does it for me, but I like the call outs, just wish there was some humor in it.
Quality, getting better, but….
Issues:
1) Ball can't make it up the ramp from a plunger shot, but does on auto. Issue is "the plunger is off center, I'll have to remount it).
2) Ball gets stuck under hulk arm on left side then it searches lifts the bridge and bridge can sometimes stay stuck in the up position. I've also had it get stuck on the inside once as well.
Sends up two balls occasionally, once the ball slammed into the trough so hard that it pushed two balls on top of the coil and left one of the opts empty, leaving it to search endlessly for "missing pinball"
3) Left in lane not lighting, oops that's just me not seeing through the plastic (covered in other post). ... lighting loki is a challenge (it would be nice if easy mode left them on between balls…..hmmm, maybe too easy) same problem with upper right lane at top….exactly what does the plastic that covers it do??
4) at first, almost thought that it needs a post between flippers, but once I changed to not going to the hulk or tesseract shot, it was less of a problem.
5) Yes side drains are very open! still deciding if I want to make the mod (other post) on using the less hard position), but probably will or I'll be the only one it the family that plays it.
6) Still trying to figure out the lighting strategy of the top lanes...
7) Something buzzes, when I hit the hawk ramp like it's trying to move but doesn't, and I also hear flasher relay but nothing flashes.
