Hello,
I noticed this when I first uploaded an avatar image, the resulting forum avatar image appears to be horizontally stretched by 15%. In order to get a result that appears to retain the desired aspect ratio, I need to reduce the horizontal dimension to 85% of the original image.
In the example below, I squished the original image to 85% before I uploaded - in the forums, the resulting image appears reasonably correct. Is this the correct approach, or am I missing some other feature? Is 85% the right correction?
