(Topic ID: 317434)
Avatar issue
By smoothbore19
57 days ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 57 days ago by smoothbore19
#1 57 days ago
I have an Avatar Pro that won't let me load any installs past easy. It has the most recent code, and plays great, but every time I try to load med, hard installs it say "can't load install". Anyone have any ideas of why it would do that? None of my other Sterns do that. I have asked in the Avatar thread a few times, and have never received any info.
#2 57 days ago
Try doing a factory reset and then load the difficulty setting.
#3 57 days ago
I reset to factory, and no luck it will not load any setting other than the two easy settings, it also will not load 3 ball, or 5 ball. It does let me load Competition. I checked all the Dips they are all set to on.
#4 57 days ago
Load the latest code again.
#5 57 days ago
Loading code again now, I was wrong before all the dips were in the off position. Should any dips be set to on durring normal play?
#6 57 days ago
CPU dip switch 8 is on during update, off when update is complete.
No idea why you can't do the installs, but you can change each of the settings in adjustments to do the exact same thing. Should be a page in the manual that shows what each install changes. Go into standard and feature adjustments and change what needs to be changed. 3 or 5 ball can be set in standard adjustments.
#7 57 days ago
I just tried installing the 1.10 code and same issue. I'll have to adjust stuff the best I can in the normal adjustments. It crazy this machine won't let me change the installs on either code 1.10 or 20
#8 57 days ago
Quoted from smoothbore19:
The 1.20 code is for Avatar LE only. Don't use that on a Pro.
From the Readme:
- Games built with CPU Part #520-5246-02 need to use V2.00 code.
- Games built with CPU Part #520-5246-00 need to use V1.10 code.
Reference: https://sternpinball.com/wp-content/uploads/2018/12/AVreadme.txt
#9 57 days ago
Quoted from Darkwing:
From the Readme:
Darkwing thank for the info. I'll load in the 1.10, I did have the 2.00 loaded.
Cleveland, OH
Arcade Upkeep
$ 11.95
$ 74.00
Lighting - Backbox
Arcade Upkeep
$ 49.99
Pinball Shark
$ 59.99
Pinball Shark
$ 6.00
$ 370.00
PinWoofer
Professor Pinball
Gweem's Mods
