So I have just installed a shaker motor and a speaker light kit on my Walking Dead. It seems that both of them aren't getting power. Is there something I am missing?
Keeping it simple here, but did you activate the motor coil?: Go to Menu Menu Diag Test Coil #8. Push the white plunger button to the left of the coin box that is pushed in when the door is closed. This energizes the high voltage so don’t touch anything else. While pushing the plunger in, push the menu button and the motor should work. If it does - awesome!!! If it doesn’t, check to see if the shaker motor is turned on and set to anything other than None. Go back to the main menu screen and press Menu Menu Adj Game and then toggle to Shaker Motor. It’s almost at the end of the options so go back instead of forward.
This page was printed from https://pinside.com/pinball/forum/topic/auxiliary-power and we tried optimising it for printing. Some page elements may have been deliberately hidden.
